Re: Support proprietary thermostat command classes
Posted: 18 Aug 2016 13:21
Thanks for getting back to me. I got the error message when using the Expert UI to try and set Fan Mode to Auto (High):
When I enter the URL directly I get a "null" response which is what is supposed to happen, so that's great. Is there something I'm missing when using the Expert UI that will result in the correct parameters being included?
Will you be able to expose the Fan Mode functions in the devices list? At the moment I only get temperature (sensor) and two meters (fan and compressor load):
(176.0.50.0)"},"permanently_hidden":false,"probeType":"meterElectric_kilowatt_per_hour","tags":[],"visibility":true,"updateTime":1471518632},{"creationTime":1471364076,"creatorId":1,"deviceType":"sensorMultilevel","h":-631951303,"hasHistory":false,"id":"ZWayVDev_zway_176-0-50-2","location":1,"metrics":{"probeTitle":"Electric","scaleTitle":"W","level":0,"icon":"meter","title":"Electric Meter (176.0.50.2)"},"permanently_hidden":false,"probeType":"meterElectric_watt","tags":[],"visibility":true,"updateTime":1471518667},{"creationTime":1471364075,"creatorId":1,"deviceType":"sensorMultilevel","h":-631972446,"hasHistory":false,"id":"ZWayVDev_zway_176-0-49-1","location":1,"metrics":{"probeTitle":"Temperature","scaleTitle":"°C","level":22,"icon":"temperature","title":"Temperature (176.0.49.1)"},"permanently_hidden":false,"probeType":"temperature","tags":[],"visibility":true,"updateTime":1471518670}]},"code":200,"message":"200 OK","error":null}
Thermostat Setpoint is not exposed because the interview process failed, but I'm not sure why the fan controls are not exposed. Is this something you will have to implement in a future release?
The thermostat is a prototype heating/cooling thermostat for the EMEA and Asian markets where fan coil units are used. It supports heating & cooling, and runs at 230 VAC for controlling up to 3 speed fan, valve (PWM @ 230 VAC or 0-10 VDC). These are the type of HVAC systems you typically see in commercial buildings, hotels, apartments, and larger homes. That's about all I can say publicly.
I'm hoping to visit IFA next month and if you're around I can tell you more about it then. I'm helping them test it now as I have a large network of Z-Wave devices in my home and the right type of HVAC system.
