ct101 thermostat
Posted: 03 Mar 2016 07:32
by deeproot
I have two ct101 thermostats..I can not change the temperature anymore.. As soon as I select the temp gauge in the UI the number continues to count up to 999c and then starts over at 1 and then continues to count.
I can not set any temp b/c the ui just takes over.
im using v2.2.1
it does this crazy temp behavior on any browser i try.
If i goto expert UI and try the system just does the old BULLSHIT of defaulting to HEAT
