LocStar lock
getshop
LocStar lock
Post by getshop »
Just received my LocStar lock and it include just fine. My problem is that the UserCode.Set(user, 200100, 1) seems to be very unreliable. It does almost never set the code correct. Yes, I do wait until the log and the code is being picked up by the lock.
To be exact I run this url:
/ZWaveAPI/Run/devices[3].UserCode.Set(1,253567,1)
What happens almost all the time is that it says this in the log:
[2016-06-21 21:59:25.376] [zway] Adding job: UserCode Set
[2016-06-21 21:59:25.377] [zway] Adding job: UserCode Get
[2016-06-21 21:59:25.381] [zway] Node 3:0 CC Security: sending Nonce Get
[2016-06-21 21:59:25.381] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-06-21 21:59:25.381] [zway] Adding job: Nonce Get
[2016-06-21 21:59:25.382] [D] [zway] SETDATA devices.3.data.lastNonceGet = 110324 (0x0001aef4)
[2016-06-21 21:59:25.392] [D] [zway] SENDING (cb 0xaa): ( 01 09 00 13 03 02 98 40 05 AA 93 )
[2016-06-21 21:59:25.394] [D] [zway] RECEIVED ACK
[2016-06-21 21:59:25.397] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-06-21 21:59:25.398] [D] [zway] SENT ACK
[2016-06-21 21:59:25.398] [D] [zway] Delivered to Z-Wave stack
[2016-06-21 21:59:26.659] [D] [zway] RECEIVED: ( 01 07 00 13 AA 00 00 7E 3F )
[2016-06-21 21:59:26.659] [D] [zway] SENT ACK
[2016-06-21 21:59:26.659] [zway] Job 0x13 (Nonce Get): Delivered
[2016-06-21 21:59:26.659] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2016-06-21 21:59:26.659] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-06-21 21:59:26.660] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 1261 (0x000004ed)
[2016-06-21 21:59:26.660] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
[2016-06-21 21:59:26.660] [D] [zway] SendData Response with callback 0xaa received: received by recipient
[2016-06-21 21:59:26.660] [D] [zway] SETDATA devices.3.data.lastSend = 110450 (0x0001af72)
[2016-06-21 21:59:26.660] [D] [zway] Job 0x13 (Nonce Get): success
[2016-06-21 21:59:26.660] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-06-21 21:59:26.660] [zway] Removing job: Nonce Get
[2016-06-21 21:59:26.669] [D] [zway] RECEIVED: ( 01 10 00 04 00 03 0A 98 80 B6 9A E1 E9 FF 8B 7C B5 63 )
[2016-06-21 21:59:26.670] [D] [zway] SENT ACK
[2016-06-21 21:59:26.670] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2016-06-21 21:59:26.670] [zway] Node 3:0 CC Security: received Nonce Report
[2016-06-21 21:59:26.670] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonce = **********
[2016-06-21 21:59:26.670] [zway] Removing job: UserCode Set
[2016-06-21 21:59:26.670] [zway] Node 3:0 CC Security: Sending a secure message
[2016-06-21 21:59:26.670] [zway] Node 3:0 CC Security: sending encrypted packet: UserCode Set
[2016-06-21 21:59:26.671] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.toFollow = False
[2016-06-21 21:59:26.671] [D] [zway] SETDATA devices.3.data.lastNonceGet = Empty
[2016-06-21 21:59:26.671] [I] [zway] Adding job: Security, UserCode Set
[2016-06-21 21:59:26.671] [I] [zway] Node 3:0 CC Security: sending Nonce Get
[2016-06-21 21:59:26.671] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-06-21 21:59:26.672] [I] [zway] Adding job: Nonce Get
[2016-06-21 21:59:26.672] [D] [zway] SETDATA devices.3.data.lastNonceGet = 110451 (0x0001af73)
[2016-06-21 21:59:26.730] [D] [zway] SENDING (cb 0xab): ( 01 25 00 13 03 1E 98 81 25 52 64 4D CF 8C 2A 9F 94 A3 6F 70 4E 8C 2D 89 B9 AD B5 B6 D5 AE 5D C4 9B 57 3A 67 05 AB E1 )
[2016-06-21 21:59:26.738] [D] [zway] RECEIVED ACK
[2016-06-21 21:59:26.739] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-06-21 21:59:26.739] [D] [zway] SENT ACK
[2016-06-21 21:59:26.739] [I] [zway] Job 0x13 (Security, UserCode Set): Response received - transfered to encapsulated jobs
[2016-06-21 21:59:26.739] [D] [zway] Delivered to Z-Wave stack
[2016-06-21 21:59:26.762] [D] [zway] RECEIVED: ( 01 07 00 13 AB 00 00 02 42 )
[2016-06-21 21:59:26.763] [D] [zway] SENT ACK
[2016-06-21 21:59:26.763] [I] [zway] Job 0x13 (Security, UserCode Set): Callback received - transfered to encapsulated jobs
[2016-06-21 21:59:26.763] [I] [zway] Job 0x13 (UserCode Set): Delivered
[2016-06-21 21:59:26.763] [D] [zway] SendData Response with callback 0xab received: received by recipient
[2016-06-21 21:59:26.763] [I] [zway] Job 0x13 (Security, UserCode Set): Delivered
[2016-06-21 21:59:26.763] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2016-06-21 21:59:26.763] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 33 (0x00000021)
[2016-06-21 21:59:26.763] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 23 (0x00000017)
[2016-06-21 21:59:26.764] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
[2016-06-21 21:59:26.764] [D] [zway] SendData Response with callback 0xab received: received by recipient
[2016-06-21 21:59:26.764] [D] [zway] SETDATA devices.3.data.lastSend = 110460 (0x0001af7c)
[2016-06-21 21:59:26.764] [D] [zway] Job 0x13 (Security, UserCode Set): success
[2016-06-21 21:59:26.765] [I] [zway] Removing job: Security, UserCode Set
[2016-06-21 21:59:26.833] [D] [zway] SENDING (cb 0xac): ( 01 09 00 13 03 02 98 40 05 AC 95 )
[2016-06-21 21:59:26.835] [D] [zway] RECEIVED ACK
[2016-06-21 21:59:26.839] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-06-21 21:59:26.839] [D] [zway] SENT ACK
[2016-06-21 21:59:26.839] [D] [zway] Delivered to Z-Wave stack
[2016-06-21 21:59:26.854] [D] [zway] RECEIVED: ( 01 07 00 13 AC 00 00 02 45 )
[2016-06-21 21:59:26.855] [D] [zway] SENT ACK
[2016-06-21 21:59:26.855] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-06-21 21:59:26.855] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2016-06-21 21:59:26.855] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-06-21 21:59:26.855] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-06-21 21:59:26.855] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
[2016-06-21 21:59:26.856] [D] [zway] SendData Response with callback 0xac received: received by recipient
[2016-06-21 21:59:26.856] [D] [zway] SETDATA devices.3.data.lastSend = 110469 (0x0001af85)
[2016-06-21 21:59:26.856] [D] [zway] Job 0x13 (Nonce Get): success
[2016-06-21 21:59:26.856] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-06-21 21:59:26.856] [I] [zway] Removing job: Nonce Get
[2016-06-21 21:59:26.874] [D] [zway] RECEIVED: ( 01 10 00 04 00 03 0A 98 80 72 1F 69 A7 85 ED CD B5 49 )
[2016-06-21 21:59:26.875] [D] [zway] SENT ACK
[2016-06-21 21:59:26.875] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2016-06-21 21:59:26.875] [I] [zway] Node 3:0 CC Security: received Nonce Report
[2016-06-21 21:59:26.875] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonce = **********
[2016-06-21 21:59:26.875] [I] [zway] Removing job: UserCode Get
[2016-06-21 21:59:26.875] [I] [zway] Node 3:0 CC Security: Sending a secure message
[2016-06-21 21:59:26.876] [I] [zway] Node 3:0 CC Security: sending encrypted packet: UserCode Get
[2016-06-21 21:59:26.876] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.toFollow = False
[2016-06-21 21:59:26.876] [D] [zway] SETDATA devices.3.data.lastNonceGet = Empty
[2016-06-21 21:59:26.876] [I] [zway] Adding job: Security, UserCode Get
[2016-06-21 21:59:26.926] [D] [zway] SENDING (cb 0xad): ( 01 1E 00 13 03 17 98 81 62 37 28 48 B5 9D F8 65 11 7A BD 60 72 72 72 3A 45 50 F8 7E 11 05 AD AB )
[2016-06-21 21:59:26.929] [D] [zway] RECEIVED ACK
[2016-06-21 21:59:26.933] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-06-21 21:59:26.934] [D] [zway] SENT ACK
[2016-06-21 21:59:26.934] [I] [zway] Job 0x13 (Security, UserCode Get): Response received - transfered to encapsulated jobs
[2016-06-21 21:59:26.934] [D] [zway] Delivered to Z-Wave stack
[2016-06-21 21:59:26.957] [D] [zway] RECEIVED: ( 01 07 00 13 AD 00 00 03 45 )
[2016-06-21 21:59:26.958] [D] [zway] SENT ACK
[2016-06-21 21:59:26.958] [I] [zway] Job 0x13 (Security, UserCode Get): Callback received - transfered to encapsulated jobs
[2016-06-21 21:59:26.958] [I] [zway] Job 0x13 (UserCode Get): Delivered
[2016-06-21 21:59:26.958] [D] [zway] SendData Response with callback 0xad received: received by recipient
[2016-06-21 21:59:26.958] [I] [zway] Job 0x13 (Security, UserCode Get): Delivered
[2016-06-21 21:59:26.958] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2016-06-21 21:59:26.959] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 26 (0x0000001a)
[2016-06-21 21:59:26.959] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 24 (0x00000018)
[2016-06-21 21:59:26.959] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
[2016-06-21 21:59:26.960] [D] [zway] SendData Response with callback 0xad received: received by recipient
[2016-06-21 21:59:26.960] [D] [zway] SETDATA devices.3.data.lastSend = 110479 (0x0001af8f)
[2016-06-21 21:59:26.960] [D] [zway] Job 0x13 (Security, UserCode Get): success
[2016-06-21 21:59:26.960] [I] [zway] Removing job: Security, UserCode Get
[2016-06-21 21:59:27.530] [D] [zway] RECEIVED: ( 01 08 00 04 00 03 02 98 40 2A )
[2016-06-21 21:59:27.530] [D] [zway] SENT ACK
[2016-06-21 21:59:27.531] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2016-06-21 21:59:27.531] [I] [zway] Node 3:0 CC Security: sending Nonce Report
[2016-06-21 21:59:27.531] [I] [zway] Adding job: Nonce Report
[2016-06-21 21:59:27.531] [D] [zway] SENDING (cb 0xae): ( 01 11 00 13 03 0A 98 80 20 33 F3 78 56 A8 F4 16 05 AE C3 )
[2016-06-21 21:59:27.540] [D] [zway] RECEIVED ACK
[2016-06-21 21:59:27.540] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-06-21 21:59:27.540] [D] [zway] SENT ACK
[2016-06-21 21:59:27.540] [D] [zway] Delivered to Z-Wave stack
[2016-06-21 21:59:27.561] [D] [zway] RECEIVED: ( 01 07 00 13 AE 00 00 02 47 )
[2016-06-21 21:59:27.561] [D] [zway] SENT ACK
[2016-06-21 21:59:27.562] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-06-21 21:59:27.562] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2016-06-21 21:59:27.562] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-06-21 21:59:27.562] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 21 (0x00000015)
[2016-06-21 21:59:27.562] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
[2016-06-21 21:59:27.562] [D] [zway] SendData Response with callback 0xae received: received by recipient
[2016-06-21 21:59:27.563] [D] [zway] SETDATA devices.3.data.lastSend = 110538 (0x0001afca)
[2016-06-21 21:59:27.563] [D] [zway] Job 0x13 (Nonce Report): success
[2016-06-21 21:59:27.563] [I] [zway] Removing job: Nonce Report
[2016-06-21 21:59:27.581] [D] [zway] RECEIVED: ( 01 1E 00 04 00 03 18 98 81 AA BE 67 9B 74 E0 9C BE 4F 1F AA DC 24 20 27 5A 31 29 F1 97 8E 7F 69 )
[2016-06-21 21:59:27.581] [D] [zway] SENT ACK
[2016-06-21 21:59:27.581] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2016-06-21 21:59:27.582] [I] [zway] Node 3:0 CC Security: Received a secure message
[2016-06-21 21:59:27.582] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = **********
[2016-06-21 21:59:27.582] [I] [zway] Node 3:0 CC Security: passing decrypted packet to application level: [ 63 03 01 00 ]
[2016-06-21 21:59:27.582] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1.status = 0 (0x00000000)
[2016-06-21 21:59:27.582] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1.code = **********
[2016-06-21 21:59:27.582] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1.hasCode = False
[2016-06-21 21:59:27.582] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1 = Empty
[2016-06-21 21:59:27.643] [D] [zway] RECEIVED: ( 01 08 00 04 00 03 02 98 40 2A )
[2016-06-21 21:59:27.643] [D] [zway] SENT ACK
[2016-06-21 21:59:27.643] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2016-06-21 21:59:27.643] [I] [zway] Node 3:0 CC Security: sending Nonce Report
[2016-06-21 21:59:27.644] [I] [zway] Adding job: Nonce Report
[2016-06-21 21:59:27.644] [D] [zway] SENDING (cb 0xaf): ( 01 11 00 13 03 0A 98 80 BF 94 83 C0 80 5C AA 5B 05 AF 03 )
[2016-06-21 21:59:27.653] [D] [zway] RECEIVED ACK
[2016-06-21 21:59:27.654] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-06-21 21:59:27.654] [D] [zway] SENT ACK
[2016-06-21 21:59:27.654] [D] [zway] Delivered to Z-Wave stack
[2016-06-21 21:59:27.673] [D] [zway] RECEIVED: ( 01 07 00 13 AF 00 00 02 46 )
[2016-06-21 21:59:27.673] [D] [zway] SENT ACK
[2016-06-21 21:59:27.673] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-06-21 21:59:27.673] [D] [zway] SETDATA devices.3.data.lastPacketInfo.delivered = True
[2016-06-21 21:59:27.673] [D] [zway] SETDATA devices.3.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-06-21 21:59:27.674] [D] [zway] SETDATA devices.3.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2016-06-21 21:59:27.674] [D] [zway] SETDATA devices.3.data.lastPacketInfo = **********
[2016-06-21 21:59:27.674] [D] [zway] SendData Response with callback 0xaf received: received by recipient
[2016-06-21 21:59:27.675] [D] [zway] SETDATA devices.3.data.lastSend = 110549 (0x0001afd5)
[2016-06-21 21:59:27.675] [D] [zway] Job 0x13 (Nonce Report): success
[2016-06-21 21:59:27.675] [I] [zway] Removing job: Nonce Report
[2016-06-21 21:59:27.693] [D] [zway] RECEIVED: ( 01 1E 00 04 00 03 18 98 81 E6 11 2A 9D D4 3D 29 C7 A9 A7 1E 47 C6 BF 21 78 B2 28 EF 4C CB 8E AB )
[2016-06-21 21:59:27.693] [D] [zway] SENT ACK
[2016-06-21 21:59:27.693] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2016-06-21 21:59:27.693] [I] [zway] Node 3:0 CC Security: Received a secure message
[2016-06-21 21:59:27.694] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = **********
[2016-06-21 21:59:27.694] [I] [zway] Node 3:0 CC Security: passing decrypted packet to application level: [ 63 03 01 00 ]
[2016-06-21 21:59:27.694] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1.status = 0 (0x00000000)
[2016-06-21 21:59:27.694] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1.code = **********
[2016-06-21 21:59:27.694] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1.hasCode = False
[2016-06-21 21:59:27.695] [D] [zway] SETDATA devices.3.instances.0.commandClasses.99.data.1 = Empty
Any experts here that can help me out? Is there something I am doing wrong?
Re: LocStar lock
May be try "1234", not 1234. Also try just 4 digits. This is manufacture specific. I see status = 0, means was not applied
