Yale Lock [Device Appears Dead]
Posted: 10 Aug 2016 21:49
Hi again, I've searched through the various threads and I'll do my best to supply all the information necessary to direct me to a solution. The lock is a Yale YRL220-ZW-619 and was purchased 2 weeks ago and installed. I've had issues and have paired/unpaired - repeat etc.
Problem:
Lock interviews perfectly when the controller (Raspberry Pi2) is within inches of the lock. I wait (perhaps not long enough) and verify that the interview is indeed complete. After I move my controller back to it's permanent location (10-15 feet away) the lock via the expert UI indicates the device seems to be dead. The closet where it's installed has a Fibaro Multi-sensor, a Fortrezz Mimolite (mains) and a few feet away there is a Aeotec Siren (mains) and Leviton Switch (mains). All working perfectly in the same/greater distance. I cannot control this lock at all using the UI (/smarthome). When operating the lock locally, nothing is updated on the UI. I've added to the log (attached) the timeframe when I unlocked the lock locally. As you can see, it appears the lock is conversing with the controller.
Edit: Or is this perhaps the resolution I'm seeking (I just don't know) ?
https://github.com/jensmoes/Niffler/issues/4
Any assistance is greatly appreciated...
Lock Firmware(tag on module):
US2.0 CP2-5-3
ZWDF806034
Device:
SDK: 4.55.0
App Version: 2.6
Network:
Vendor: RaZberry by Z-Wave.Me
Z-Wave Chip: ZW0500
SDK 6.51.03
Serial API Version: 05.00
Version number: v2.2.2
Compile-ID: d2212e41b6487bf6efe6df730db05571edc64915
Compile-Date: 2016-04-11 11:00:34 +0300
Problem:
Interview-Status
Interview complete
Wireless Activity
Device seems to be dead
Application version
21.32
SDK version
4.53.00
Command Class
Basic, DoorLockLogging, ScheduleEntryLock, DoorLock, UserCode, Configuration, Alarm, ManufacturerSpecific, Protection, Battery, Association, Version, Time, TimeParameters, Security,
Security interview (check mark)
US2.0 CP2-5-3
ZWDF806034
Device:
SDK: 4.55.0
App Version: 2.6
Network:
Z-Wave Chip: ZW0500
SDK 6.51.03
