Fibaro FGS-222 relay association
Posted: 24 Aug 2016 12:53
Hello together!
I have 2 Fibaro FGS-222 relay and i would like to keep switch 1 and 2 of both relays in sync.
How can I achieve this with associations??
Relay A:
In group 1 I have: (#1.1) Z-Way & (#3.0) Fibaro Relay B
In group 2 I have: (#1.2) Z-Way & (#3.2) Fibaro Relay B
Relay B:
In group 1 I have: (#1.1) Z-Way & (#2.0) Fibaro Relay A
In group 2 I have: (#1.2) Z-Way & (#2.2) Fibaro Relay A
If I press switch one on relay a, then switch 1 on relay b is not changed. What did I wrong?
Background:
In the living room I have 2 lights which are switchted with relay A switch 1 & 2
Now I need two switches in a different place in the room, but there is no connection to the lights or to the relay a.
My idea is to install two new switches connected to relay b. With relay a & relay b switch 1 it should be possible to switch light 1 on and off. With relay a & relay b switch 2 it should be possible to switch light 2 on and off.
Power supply for relay b (N&L) is available.
Relay A:
Relay B:
Background:
