The ZFM-80 looks like the relay can handle the 120v and z-wave. Check and Check. There is also a external switch connector. Maybe check?
I included a snippet that shows the diagram and configuration options. I am pretty sure I could use type c/d to get some what the effect I want, but if the rocker switch is flipped at the walk in door, then I have to flip it off. Looking at types a/b, the language does not sound like a momentary type switch. Is this correct?
On one hand that does not make sense, I am wonder if I want to configure it as B, that would be like my Door Bell switches. Is this correct?
Update 10/13/2011
The answer I found out is, NO. The default is type C. The Tuxedo can not send configurations at this time. The only way I can accomplish what I want, is the use the ZFM-80, and the dry contact I am using today is a "LNC Closerse".
Today I have a transformer for the low voltage pulse to the relay. If I could have set the ZFM-80 to type A, then I could use the doorbell switches straight to the ZFM-80 external switch contacts.
