GE Smart Fan Control In-Wall 12730
Posted: 21 Dec 2016 05:27
by jadedeane
Has anyone used one of these with Z-Way?
https://byjasco.com/products/ge-z-wave- ... an-control
I don't see it listed as a device under GE's line of products (regular in-wall binary and dimmer switches are there, have a ton of those).
Thanks!
Re: GE Smart Fan Control In-Wall 12730
Posted: 22 Dec 2016 00:10
by CudaNet
Yes, I have one that I use. Just make sure you add it to Niffler.
Posted: 22 Dec 2016 01:26
by jadedeane
Ah yes, was going to assume like the other "dimmers" I'd add it to Niffler. Thanks for the reminder.
How has the switch worked for you? Any issues/tips/warnings?
Would you happen to have a screenshot, or could you comment on what configuration profile you selected for the switch (if any, given it's not listed under GE options)?
Thanks!
Posted: 23 Dec 2016 00:16
by CudaNet
The switch has worked great, no problems at all (under v2.2.3). Right now, I'm just using the default configuration with a param to disable the LED when the fan is on. If you wanted to to select a config, you could opt for the GE In Wall Dimmer as this is basically a dimmer switch.
Device Id
34
Device Name Master Fan
Device type Routing Multilevel Switch
Interview-Status Interview complete
Wireless Activity active
Application version 3.10
SDK version 4.55.00
Command Class
Basic, SwitchMultilevel, SwitchAll, Configuration, ManufacturerSpecific, Version,
jadedeane wrote:Ah yes, was going to assume like the other "dimmers" I'd add it to Niffler. Thanks for the reminder.
Thanks!
Posted: 23 Dec 2016 00:41
by jadedeane
Perfect, thanks!
