Fibaro Dimmer 2, duplicate devices
Bofur
Post by Bofur »
I have just recently installed some Fibaro Dimmer 2 (FGD-212) units. When adding them as a new device, each dimmer ends up with a whole heap of "devices" (I'm running Z-Way 2.3.6). One example gives me all the following:
- Fibaro Dimmer 2
- Current consumption (26.1)
- Fibaro Dimmer (26.1)
- Fibaro Dimmer (26.2)
- Fibaro Heat Alarm (26.1)
- Fibaro Power Management Alarm (26.1)
- Fibaro System Alarm (26.1)
- Total consumption (26.1)
I understand the various names, and that there has to be two "Fibaro Dimmer" devices (because you can use two switches with the dimmer, 26.1 and 26.2), but why is there so many duplicate alarm devices? Can I disable all duplicates?
I found the same question in the Russian forum (viewtopic.php?t=25354), but as I don't speak the language, and Google Translate wasn't too helpful, I was hoping somebody could help me out here as well!
IgoriokLT
Re: Fibaro Dimmer 2, duplicate devices
Post by IgoriokLT »
I just deactivated the rest of the devices leaving only dimmer I use. It seems to be Fibaro`s feature.
