VISION In-Wall Dual Relay Switch ZL7432 status update problem
joluzu
Post by joluzu »
both relays works from the interface.
but only sw1 update the GUI after a manual change.( sw2 don't update the GUI).
in the device manual I found the reason :
"For Wall SW1, ZL 7432 will report the status of On/OFF after doing “Association”.
However, Wall SW2 will only report the status if Z-Wave™ Interface Controller
support Multi Channel command, and send Get Command to ask ZL 7432 Wall SW
2 to report the status."
but I don't know how can achieve this.
thank you in advanced for your help
joluzu
Re: VISION In-Wall Dual Relay Switch ZL7432 status update problem
Post by joluzu »
is somebody is interested I found the workaround:
basically when s2 is switched manually. the device send the status of the s1 to the controller. at that point you must update s2 getting the status update
