Qubino Flush 2 Relays keep failure
steffo89
Post by steffo89 »
The device loses its setting on a regular basis. about every other week. I can not understand why, maybe someone can help me understand the log. Attach parts that concern the latest error for node 41.
Log:
[2018-12-06 08:19:21.419] [core] --- ZWayVDev_zway_41-1-37 performCommand processing: {"0":"off"}
[2018-12-06 08:19:21.419] [zway] Adding job: SwitchBinary Set
[2018-12-06 08:19:21.419] [zway] Adding job: SwitchBinary Get
[2018-12-06 08:19:21.424] [D] [zway] SENDING (cb 0x9d): ( 01 0E 00 13 29 07 60 0D 00 01 25 01 00 25 9D 3C )
[2018-12-06 08:19:21.426] [D] [zway] RECEIVED ACK
[2018-12-06 08:19:21.430] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2018-12-06 08:19:21.430] [D] [zway] SENT ACK
[2018-12-06 08:19:21.430] [D] [zway] Delivered to Z-Wave stack
[2018-12-06 08:19:21.597] [D] [zway] RECEIVED: ( 01 07 00 13 9D 00 00 11 67 )
[2018-12-06 08:19:21.597] [D] [zway] SENT ACK
[2018-12-06 08:19:21.598] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2018-12-06 08:19:21.598] [D] [zway] SendData Response with callback 0x9d received: received by recipient
[2018-12-06 08:19:21.598] [D] [zway] SETDATA devices.41.data.lastSendInternal = **********
[2018-12-06 08:19:21.598] [D] [zway] SETDATA devices.41.data.lastSend = 115042675 (0x06db6973)
[2018-12-06 08:19:21.598] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2018-12-06 08:19:21.598] [zway] Removing job: SwitchBinary Set
[2018-12-06 08:19:21.638] [D] [zway] SENDING (cb 0x9e): ( 01 0D 00 13 29 06 60 0D 00 01 25 02 25 9E 3E )
[2018-12-06 08:19:21.640] [D] [zway] RECEIVED ACK
[2018-12-06 08:19:21.644] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2018-12-06 08:19:21.644] [D] [zway] SENT ACK
[2018-12-06 08:19:21.644] [D] [zway] Delivered to Z-Wave stack
[2018-12-06 08:19:21.811] [D] [zway] RECEIVED: ( 01 07 00 13 9E 00 00 10 65 )
[2018-12-06 08:19:21.811] [D] [zway] SENT ACK
[2018-12-06 08:19:21.811] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2018-12-06 08:19:21.812] [D] [zway] SendData Response with callback 0x9e received: received by recipient
[2018-12-06 08:19:21.812] [D] [zway] SETDATA devices.41.data.lastSendInternal = **********
[2018-12-06 08:19:21.812] [D] [zway] SETDATA devices.41.data.lastSend = 115042696 (0x06db6988)
[2018-12-06 08:19:21.812] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2018-12-06 08:19:21.812] [zway] Waiting for job reply: SwitchBinary Get
[2018-12-06 08:19:21.944] [D] [zway] RECEIVED: ( 01 0D 00 04 00 29 07 60 0D 01 00 25 03 00 92 )
[2018-12-06 08:19:21.944] [D] [zway] SENT ACK
[2018-12-06 08:19:21.944] [D] [zway] SETDATA devices.41.data.lastReceived = 0 (0x00000000)
[2018-12-06 08:19:21.944] [D] [zway] Received reply on job (SwitchBinary Get)
[2018-12-06 08:19:21.945] [D] [zway] SETDATA devices.41.instances.1.commandClasses.37.data.level = False
[2018-12-06 08:19:23.949] [D] [zway] Job 0x13: deleted from queue
[2018-12-06 08:19:31.155] [core] --- ZWayVDev_zway_41-1-37 performCommand processing: {"0":"off"}
[2018-12-06 08:19:31.156] [zway] Adding job: SwitchBinary Set
[2018-12-06 08:19:31.156] [zway] Adding job: SwitchBinary Get
[2018-12-06 08:19:31.161] [D] [zway] SENDING (cb 0x9f): ( 01 0E 00 13 29 07 60 0D 00 01 25 01 00 25 9F 3E )
[2018-12-06 08:19:31.163] [D] [zway] RECEIVED ACK
[2018-12-06 08:19:31.168] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2018-12-06 08:19:31.168] [D] [zway] SENT ACK
[2018-12-06 08:19:31.168] [D] [zway] Delivered to Z-Wave stack
[2018-12-06 08:19:31.335] [D] [zway] RECEIVED: ( 01 07 00 13 9F 00 00 11 65 )
[2018-12-06 08:19:31.335] [D] [zway] SENT ACK
[2018-12-06 08:19:31.335] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2018-12-06 08:19:31.335] [D] [zway] SendData Response with callback 0x9f received: received by recipient
[2018-12-06 08:19:31.336] [D] [zway] SETDATA devices.41.data.lastSendInternal = **********
[2018-12-06 08:19:31.336] [D] [zway] SETDATA devices.41.data.lastSend = 115043632 (0x06db6d30)
[2018-12-06 08:19:31.336] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2018-12-06 08:19:31.336] [I] [zway] Removing job: SwitchBinary Set
[2018-12-06 08:19:31.375] [D] [zway] SENDING (cb 0xa0): ( 01 0D 00 13 29 06 60 0D 00 01 25 02 25 A0 00 )
[2018-12-06 08:19:31.377] [D] [zway] RECEIVED ACK
[2018-12-06 08:19:31.381] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2018-12-06 08:19:31.381] [D] [zway] SENT ACK
[2018-12-06 08:19:31.381] [D] [zway] Delivered to Z-Wave stack
[2018-12-06 08:19:31.547] [D] [zway] RECEIVED: ( 01 07 00 13 A0 00 00 10 5B )
[2018-12-06 08:19:31.547] [D] [zway] SENT ACK
[2018-12-06 08:19:31.547] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2018-12-06 08:19:31.548] [D] [zway] SendData Response with callback 0xa0 received: received by recipient
[2018-12-06 08:19:31.548] [D] [zway] SETDATA devices.41.data.lastSendInternal = **********
[2018-12-06 08:19:31.548] [D] [zway] SETDATA devices.41.data.lastSend = 115043653 (0x06db6d45)
[2018-12-06 08:19:31.548] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2018-12-06 08:19:31.548] [I] [zway] Waiting for job reply: SwitchBinary Get
[2018-12-06 08:19:31.680] [D] [zway] RECEIVED: ( 01 0D 00 04 00 29 07 60 0D 01 00 25 03 00 92 )
[2018-12-06 08:19:31.680] [D] [zway] SENT ACK
[2018-12-06 08:19:31.680] [D] [zway] SETDATA devices.41.data.lastReceived = 0 (0x00000000)
[2018-12-06 08:19:31.680] [D] [zway] Received reply on job (SwitchBinary Get)
[2018-12-06 08:19:31.681] [D] [zway] SETDATA devices.41.instances.1.commandClasses.37.data.level = False
[2018-12-06 08:19:33.695] [D] [zway] Job 0x13: deleted from queue
[2018-12-06 08:19:40.421] [D] [zway] RECEIVED: ( 01 08 00 04 00 29 02 5A 01 83 )
[2018-12-06 08:19:40.421] [D] [zway] SENT ACK
[2018-12-06 08:19:40.422] [D] [zway] SETDATA devices.41.data.lastReceived = 0 (0x00000000)
[2018-12-06 08:19:40.422] [D] [zway] SETDATA devices.41.instances.0.commandClasses.90.data.reset = True
[2018-12-06 08:19:40.439] [I] [core] Notification: error (connection): User reset to factory defaults Z-Wave device ID: 41
[2018-12-06 08:19:40.444] [I] [core] Notification: error (connection): User reset to factory defaults Z-Wave device ID: 41
