Fibaro door sensor sporadically getting out of sync
Posted: 07 Nov 2020 11:33
I have a Fibaro door sensor FGK-10x, included securely, to monitor a garage door. Every couple of weeks or even months, the sensor acts up and remains stuck in "open" mode. Upon closing it briefly hits "closed", then quickly (1 s) falls back to "open". It is independent of the battery or ambient temperature. The only cure in this situation is to briefly remove the battery. Has anyone seen this? Faulty unit?
I'm using two other FGKs without issue, although one of them is the non-plus version and the other one was not included securely for some reason.
