qubino thermostat 2 (ZMNKID1) cant set offset
Posted: 25 Feb 2021 17:42
by seiken
Hi
when adding my Qubino thermostat 2, ZMNKID1 i cant change the value for parameter 110,
it only show checkboxes. and doing it in expert will result in error, exempel i need to lower the temp with -44 (-4.4C)
the device starts clicking and showing 65492 and no change is made to the displayed temperature.
if i change it to 44 (without -) then i changes to this but it doesnt change the display temp.
i have the same behavior on 7 devices (tested on a total of 8 devices all doing the same thing)
Skärmbild (24).png (608.47 KiB) Viewed 14687 times
Skärmbild (25).png (368.05 KiB) Viewed 14687 times
//Regards
Re: qubino thermostat 2 (ZMNKID1) cant set offset
Posted: 25 Feb 2021 23:24
by piet66
I doubt that the expert mode accepts negative numbers. You will have to convert your input.
I don't know ZMNKID1, in other Qubino devices 0°C = 32536. I suspect that the description is wrong.
Posted: 26 Feb 2021 03:31
by seiken
piet66 wrote:
25 Feb 2021 23:24
hi
il talk to qubino and they claim it should be -44 thay are sending new thermostat 2 modul to me with a modified firmware to try, if it works they will update my other qubino thermostat 2.
questone, basically every device i ad, it chooses the wrong type, instead of EU version i pick some other version, then when i manually set it to the correct devices it displays error in settings, the device is in default state.
Is this normal?
Skärmbild (26).png (515.47 KiB) Viewed 14657 times
Skärmbild (45).png (534.39 KiB) Viewed 14657 times
