WiDom Energy Driven Switch - can't include the device in the network
Miklux
Post by Miklux »
Hi all,
I have a little problem... I'm trying to include an Energy Driven Switch (Widom) with my ZWave network.
I'm using a Raspberry with ZWay installed and the UZB connected and working properly (I have other devices, like Zuno working correctly).
The first problem is that in the WiDom products list, I do not see the Energy Driven Switch but only the ZWave double switch.
But some times ago I included the device with no problems and now is impossible. :roll:
Do you have some suggestion?
The software versione is the v3.2.3
The UI versione is v1.5.9
The serial api versione is the 5.26
Where is the problem?
Thank you in advance for your help or suggestion,
best regards,
Miklux
Re: WiDom Energy Driven Switch - can't include the device in the network
Hello!
What do you mean by "I do not see the Energy Driven Switch but only the ZWave double switch". Where do you see it?
"Impossible to include" means it is not included at all? Or it is not included as you expected? Please provide more details.
Miklux
Post by Miklux »
PoltoS wrote:
16 Jun 2022 01:46
Hello!
Hi Poltos, thank you for your reply.
In the Zway vendors page, I see the WiDom icon and if I click on it, in the products page I see only one device named "Z-Wave Double Switch".
If I select this device and try to add the device to my Z-wave network, the inclusion process do not works.
I tried also the inclusion using the option "Add new Z-Wave DEvice and identify it automatically" but also in this case the inclusion process do not works.
The vendor instructions decribes the inclusion process in this way:
the device supports the Network Wide Inclusion (NWI) and the Normal Inclusion
A single click on the B button starts the normal inclusion and after 2 seconds , if the controller do not start the normal inclusion, it will start the NWI.
I tried to follow this instructions but nothing appens. If i click in the "Start" button in the "Add new device" window, after some minute the ZWay shows the window "SmartHome UI - Warning" - "INCLUSION takes too long to start up"
Where is the problem? Maybe I'm doing something wrong?
Thank you for your attention,
best regards,
Miklux
enbemokel
Post by enbemokel »
Did you try expert menu to include, and can you see something in job menu?
Miklux
Post by Miklux »
enbemokel wrote:
16 Jun 2022 12:32
Hi enbemokel,
in the expert menu the "Start Inclusion" button is disabled and only the "start exclusion" button is enabled.
Now I see that i require a license but I already entered and validated it.... maybe this is the problem?
It might be a license problem or a frequency issue.
Miklux
Post by Miklux »
PoltoS wrote:
17 Jun 2022 03:15
How could I solve this issue?
Please show the log during inclusion. If there is just nothing appearing during the button clicks, check:
1) that device and controller frequencies are same
2) try to rest the device first
3) try to exclude the device first
Miklux
Post by Miklux »
PoltoS wrote:
25 Jun 2022 02:33
Hi PoltoS,
first of all thank you for your attention.
How and where i can see the log ?
I already followed these steps 1), 2) and 3) but noting change.
Miklux
Post by Miklux »
PoltoS wrote:
25 Jun 2022 02:33
Hi PoltoS,
another question:
in the Expert UI , in the Network>Control page, i read this:
Controller is secondary in the network. It can not add/remove devices to/from the network. Use your primary controller to add new devices and delete old.
Controller is in normal mode
What it means "is secondary in the network" ?
