Popp 433 Bridge not working
gwaterst
Post by gwaterst »
I have recently purchased a Popp 433 Gateway, and it is properly connected to my Wifi Network and in the "433" app shown as connected.
I can, however not get it to working.
When teaching in a device (a remote control), the following is happening:
1. it is receiving a signal approx 1/s with an empty "pulse train"
2. when pressing a button on the remonte control it is receiving a pulse train correctly
3. when pressing the test button in the z-way software, nothing happens. The server-log outputs the following:
It is correctly detecting sent codes from a remote control. However, nothing is happening when I click on the "Test" button and the z-way-server.log shows:
[2023-04-07 10:50:26.822] [E] [HTTP] Callback execution error: TypeError: Cannot set property 'Access-Control-Allow-Origin' of undefined
at WebServer.ws.addHTTPHeaders (automation/Webserver.js:176:45)
at WebServer.document_root (automation/Webserver.js:26:16)
And when saving the config, it loses connection:
[2023-04-07 10:51:01.487] [core] --- RF433.stop()
[2023-04-07 10:51:01.487] [core] --- RF listner stop
[2023-04-07 10:51:01.487] [core] GWListener close
[2023-04-07 10:51:01.561] [core] Clients: 0
[2023-04-07 10:51:01.562] [core] --- Delete devices
[2023-04-07 10:51:01.563] [core] --- Stopping module RF433
[2023-04-07 10:51:01.565] [core] --- Starting module RF433
[2023-04-07 10:51:02.251] [core] Onclose
[2023-04-07 10:51:02.251] [core] remoteHost 0.0.0.0
[2023-04-07 10:51:02.251] [core] remotePort 8000
[2023-04-07 10:51:02.572] [I] [core] false
[2023-04-07 10:51:07.062] [I] [core] Connecting...
[2023-04-07 10:51:07.627] [I] [core] RF listener
[2023-04-07 10:51:09.558] [D] [zway] Job 0x3a: deleted from queue
[2023-04-07 10:51:12.084] [I] [core] Connecting...
[2023-04-07 10:51:12.683] [I] [core] RF listener
[2023-04-07 10:51:12.706] [I] [core] Onclose
[2023-04-07 10:51:12.706] [I] [core] remoteHost 0.0.0.0
[2023-04-07 10:51:12.707] [I] [core] remotePort 8000
[2023-04-07 10:51:13.692] [I] [core] false
Is this a known problem, and how could I make it work again?
Re: Popp 433 Bridge non working
This product is EOL for many years now. I think you need to contact Popp to get support.
gwaterst
Post by gwaterst »
You are right, of course. But Z-Way is listing the device as officially supported on its homepage:
https://z-wave.me/manual/z-way/Extendin ... 0000000000
This made me considering to buy the device in the first place. I would be fine with the device not being supported anymore. But then it should also be removed from the Z-Way manual.
For now, I will contact Popp.
gwaterst
Post by gwaterst »
A quick update:
Popp's support has confirmed that the 433 Bridge is not anymore working with the Z-Way interface, and I receive a refund for my purchase.
I would advocate for removing the device from the Manual then and having a note in the description of the app that it is not anymore functional.
Re: Popp 433 Bridge not working
Well noted, we will remove it from the manual. Thanks for your feedback!
