Page 1 of 3
FGS-213
Posted: 28 May 2023 17:33
by MrM.
Is there a bug in the Fibaro FGS-213 device, as the Watts used are missing?
I have some FGS-223 devices. They all show the Current consumption in a separate box in the normal user interface, when I look in a room:
http://127.0.01:8083/smarthome/#/rooms/2 It shows:
XX Current consumption S1 5W
I have some FGS-213 devices. They do not show the Current consumption in a separate box in the normal user interface, when I look in a room:
http://127.0.01:8083/smarthome/#/rooms/2 the current consumption entry is missing, they do not have a current consumption box like the FGS223.
Although when I look in the expert interface in
http://127.0.0.1:8083/expert/#/control/sensors I can see the X Watts used.
The reported Z-wave capabilities in the expert interface are the same for both Fibaro devices.
Re: FGS-213
Posted: 31 May 2023 03:08
Do you mean, expert UI shows the Meter W consumption, while in Smart Home UI it is not? This might be related to a bug fixed in
https://storage.z-wave.me/z-way-server/ ... _armhf.deb (W is not shown on the last channel). But in that case it would be absent in the Expert UI too.
Re: FGS-213
Posted: 31 May 2023 13:16
by MrM.
I am using Ubuntu AMD64. I Can't use the provided package architecture (armhf).
Is there a link for amd64?
Yes in the expert UI I can see the Meter W consumption of Fibaro FGS-213 devices on the following page:
Sensor data
# Device Name Device Type Level Scale Date
11 NameDevice Electric 23 W 2023-05-28
If I open a room eg:
http://127.0.0.1:8083/smarthome/#/rooms/5 in the default GUI (non expert) the Meter W consumption is not shown.
For FGS-223 devices in the same room the W consumption is shown, all Fibaro FGS-223 devices have a child entity with labels like "Current consumption S1"
Re: FGS-213
Posted: 02 Jun 2023 02:17
Please go in
http://127.0.0.1:8083/smarthome/#/zwave/devices/11 and check if the corresponding item is hidden
Re: FGS-213
Posted: 02 Jun 2023 11:39
by MrM.
The Normal device view of the FGS-213:
The current consumption is missing.
The Senor view of the same device in the expert GUI.
The Normal device view of the FGS-223:
It has current consumption.
Re: FGS-213
Posted: 02 Jun 2023 12:54
Don't you ask for this device? It corresponds to the one you see in the Expert UI
Re: FGS-213
Posted: 02 Jun 2023 13:25
by MrM.
Yes, I have a 11.1 entity for the FGS-213. But only one for KWh. The current consumption is missing, athough in the expert interface Watts are shown (see post 5). For the FGS-223 there a two 6.1 entities. See the screenshots for both devices below.
FGS-213, one entity (only kWh):
FGS-223, two entities (kWh and Watts):
According to Fibaro both decvices should have the same capabilities, the first is the single switch the second is the double switch.
In the software they show not the same.
Re: FGS-213
Posted: 07 Jun 2023 01:43
by MrM.
Is there news about the FGS-213 and the missing device?
Re: FGS-213
Posted: 13 Jun 2023 01:44
Please show the Meter data tree in expert UI for 6:1 Meter and 11:1 Meter
Re: FGS-213
Posted: 13 Jun 2023 10:41
by MrM.
I openend the following page for the below screenshots:
http://127.0.0.1:8083/expert/#/control/meters
I hope this is the correct Meters view?
FGS-223, has three entities:
FGS-213, has entities :
