MCO MH-DT411
topcatsss
MCO MH-DT411
Post by topcatsss »
Hi there
i can't find this device in the Device Description list
Dimmer Switch MH-DT411
How can one add the device so it can be configured nicely?
I have the PDF with all the information (but apparently uploading a 1.8mb pdf is not allowed ;( )
Below is the ZDDX
<ZWaveDevice xmlns="http://www.pepper1.net/zwavedb/xml-schemata/z-wave" schemaVersion="2">
	<descriptorVersion>1</descriptorVersion>
	<deviceData>
		<manufacturerId value="015f"/>
		<productType value="d411"/>
		<productId value="5102"/>
		<libType value="03"/>
		<protoVersion value="04"/>
		<protoSubVersion value="3e"/>
		<appVersion value="03"/>
		<appSubVersion value="03"/>
		<basicClass value="04"/>
		<genericClass value="11"/>
		<specificClass value="01"/>
		<optional value="true"/>
		<listening value="true"/>
		<routing value="true"/>
		<beamSensor>0</beamSensor>
	</deviceData>
	<deviceDescription>
		<description>
			<lang xml:lang="en"/>
		</description>
		<wakeupNote>
		</wakeupNote>
		<inclusionNote>
		</inclusionNote>
		<productName/>
		<brandName/>
		<productVersion>3.3</productVersion>
	</deviceDescription>
	<commandClasses>
		<commandClass id="0020" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0026" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="002b" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="002c" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0032" version="3" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0059" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="005a" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="005e" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0070" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0071" version="4" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0072" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0073" version="1" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="007a" version="4" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0085" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
		<commandClass id="0086" version="2" supported="true" controlled="false" secure="false" inNIF="true"/>
	</commandClasses>
	<assocGroups>
		<assocGroup number="1" maxNodes="1">
			<description>
				<lang xml:lang="en">Group 1</lang>
			</description>
		</assocGroup>
		<assocGroup number="2" maxNodes="5">
			<description>
				<lang xml:lang="en">Group 2</lang>
			</description>
		</assocGroup>
		<assocGroup number="3" maxNodes="5">
			<description>
				<lang xml:lang="en">Group 3</lang>
			</description>
		</assocGroup>
		<assocGroup number="4" maxNodes="5">
			<description>
				<lang xml:lang="en">Group 4</lang>
			</description>
		</assocGroup>
	</assocGroups>
</ZWaveDevice>
seattleneil
Re: MCO MH-DT411
Post by seattleneil »
ZDDX .xml files are maintained by the Z-Way developers. As you noted, ZDDX .xml files provide the Z-Way UI with user-friendly information about configuration options and association groups. From a practical standpoint, requiring the Z-Way developers to maintain a device-specific file for every new Z-Wave device is a giant pain in the neck. To make the situation even worse, a new version of device firmware can require maintaining device-specific and version-specific files. The only good news to the ZDDX file maintenance nightmare is that newer versions of the Z-Wave standard allow the firmware itself to contain user-friendly configuration options descriptions and association group descriptions. The newer Z-Wave standards eliminate the need for Z-Way developers to maintain ZDDX files for those devices where the firmware contains the user-friendly information.
Unfortunately, the firmware in the MCO MH-DT411 does not contain the user-friendly information for configuration options and association groups. This means a ZDDX device file is required. One approach is that you could create a custom ZDDX .xml file, test it and then request the Z-way developers to add the file to their repository of ZDDX files. Be sure to run "python ./MakeIndex.py" so that your custom ZDDX .xml file is recognized by Z-Way.
If you're not willing to create and test a custom ZDDX file, then you'll need to make a request for the Z-Way developers to create the ZDDX file and be patient.
If you're willing to go to the effort to create a custom ZDDX .xml file, I suggest starting by taking the ZDDX output you provided and replace "Group 1" descriptive text with something like "Group 1 for Lifeline", "Group 2" with "Group 2 for Multilevel", etc. Once you understand how to create the .xml file and customize the association group information, you can tackle the configuration options information. I suggest you look at this .xml file as an example: 910-0178-5343-4735-04-06-51-00-00.xml (be sure to use an xml pretty printer to nicely parse the example file). Using the example file as a template, I then suggest converting the zwave-js device file for the for MCO MH-DT411 (https://github.com/zwave-js/node-zwave- ... ces/0x015f, file: mh-dt311_411.json) which is written in JSON format to Z-Way's xml format.
Good luck.
topcatsss
Re: MCO MH-DT411
Post by topcatsss »
Hi there
Yes quite happy to start to dig into this, and share the results.
You mentioned the 910-0178-5343-4735-04-06-51-00-00.xml file, where is this?
I'm guessing somewhere this is a nice document outlining the build/publish process :)
seattleneil
Re: MCO MH-DT411
For linux-based Z-Way versions, the ZDDX files are in directory /opt/z-way-server/ZDDX. There are over 4000 .xml files. The 910-0178-5343-4735-04-06-51-00-00.xml file is simply 1 of the .xml files that has a lot of values populated. The purpose behind my suggestion was to not have to start from an empty .xml file.
The on-line version of the Z-Way user manual is here: https://z-wave.me/files/manual/z-way/#
Unfortunately, the process for creating a ZDDX file does not appear to be documented. The good news is that if you're comfortable with editing xml, the learning curve is pretty easy to climb.
piet66
Re: MCO MH-DT411
Post by piet66 »
I once faced the same problem and reported my findings here at the time:
[HowTo] create a correct device description (xml, ZDDX)
