[HowTo] improve Razberry signal strength (antenna upgrade)
Esmax666
Re: [HowTo] improve Razberry signal strength (antenna upgrade)
Post by Esmax666 »
The picture are no more there ? i don t understand on wich L1 i have to connect the antenna
Thx
Krooms
Post by Krooms »
cyberhofi was last active on November 12th in 2016, so I don't think, that he's gonna reupload the pictures.
Maybe some of the admins could take a look why the attached pictures are gone.
Bjork
Post by Bjork »
In all honesty if you have access to USB ports I’d go that route if possible. It will be simpler than soldering on an antenna or a connector pad. There’s a couple videos on YouTube of attempts but iirc they don’t make much difference.
Your best option is to find a USB adapter that’s compatible. Models may be available that offer connectors for high gain antennas. These will serve you better imo than trying to solder your pi a longer antenna.
You could also look into power line Ethernet or Moca to help extend your network.
2014
