[userModule] Advanced Thermostat Device (Updated 2016/12/05)
Posted: 20 Feb 2016 20:03
This module combines multiple actors and temperature sensors to form a thermostat. The actor will be turned on or off depending on the temperatures measured and a setpoint defined by a virtual thermostat.
Compared to the default "Thermostat Device" module this module adds additional functionality
Bug/Issue tracker at https://github.com/maros/Zway-AdvancedT ... ice/issues
Documentation at https://github.com/maros/Zway-AdvancedT ... /README.md
Download at https://github.com/maros/Zway-AdvancedT ... e/releases
Installation can be done directly via git or via the the Zway App-Store. Install the BaseModule first.
- Check for opened windows and inhibit heating while windows are opened
- Ability to reuse existing thermostat modules (will only create a virtual thermostat if none is configured)
- Add multiple temperature sensors
- Add multiple heating actors
- Optionally ensure max heating interval length, and minimum breaks between heating cycles to prevent overheating (ideal for infrared heating panels)
- Switch to disable thermostat operation entirely
