[userModule] Synology Recording
fez
Post by fez »
This module will enable you to start / stop recording of a camera configured in the Synology Surveillance Station and as such enable you to trigger the recording with z-wave devices or events. It creates a virtual binary switch: on - starts recording, off - stops recording. Based on the provided credentials it will log in, send the given start / stop command and then log out.
This is a more user friendly version of the Synology Surveillance Station (SSS) Web API switch module, offering only recording control.
Token: fermit_beta
podultrasound
Re: [userModule] Synology Recording
Post by podultrasound »
What a great idea?! Download granny 2.0
fez
Post by fez »
Added http option.
This could be used as a workaround in case of certificate issues when used via IP on local network.
