[userModule] Synology Recording
Posted: 30 Sep 2018 22:35
by fez
This module will enable you to start / stop recording of a camera configured in the Synology Surveillance Station and as such enable you to trigger the recording with z-wave devices or events. It creates a virtual binary switch: on - starts recording, off - stops recording. Based on the provided credentials it will log in, send the given start / stop command and then log out.
This is a more user friendly version of the Synology Surveillance Station (SSS) Web API switch module, offering only recording control.
Token: fermit_beta
Re: [userModule] Synology Recording
Posted: 03 Apr 2019 07:09
by podultrasound
What a great idea?! Download granny 2.0
Posted: 16 Oct 2020 10:46
by fez
Added http option.
This could be used as a workaround in case of certificate issues when used via IP on local network.
