Re: COMMAND_CLASS_SOUND_SWITCH support
Posted: 27 May 2024 09:11
Yeah I have a similar work-around in place. Was just curious to whether the actual problem had been addressed somehow.seattleneil wrote: ↑23 May 2024 18:33A potential work-around is to the "Virtual Device (JavaScript)" app (aka CodeDevice module) to create a multilevel switch, where the
command is something like: zway.devices[ZWAVE_DEVICE_ID].instances[CHANNEL_ID].commandClasses[0x79].Set(8,%%). Please understand that you'll need to determine the correct command to control the tone for a channel which you can do using the Expert UI. The virtual device will appear as a dimmer switch on the smarthome/normal UI where the dimmer level will be the tone. You can then change the icon from a light bulb to something more meaningful.
