App for Fibaro switch
Christian12
Post by Christian12 »
That switches can be activated with alarm sequences, an app to send out wich alarm should the switch act would be nice.
in ExpertUI Options but i don't know how to send Alarmmodes to actor:
Nº 30 - General Alarm Set - Relay 1
Deactivated, devices does not react to alarms
Disable on Alarm - will switch off in case of alarm
Enable on Alarm - will switch on in case of alarm
Flashing on Alarm - will switch on and off periodically for 10 minutes
Updated: 07.01.2016 | Set value: 3 | Default value is: Flashing on Alarm - will switch on and off periodically for 10 minutes
This defines the behavior of relay 1 in case of general alarms
Save this parameter Set to default
Nº 31 - Flood Alarm Set - Relay 1
Updated: 07.01.2016 | Set value: 2 | Default value is: Enable on Alarm - will switch on in case of alarm
This defines the behavior of relay 1 in case of flood alarms
Nº 32 - Smoke Alarm Set - Relay 1
This defines the behavior of relay 1 in case of smoke alarms
Nº 33 - Temperature Alarm Set - Relay 1
Updated: 07.01.2016 | Set value: 1 | Default value is: Disable on Alarm - will switch off in case of alarm
This defines the behavior of relay 1 in case of temperature alarms
Nº 39 - Active flashing alarm time
Updated: 07.01.2016 | Set value: 600 | Default value is: 0
Defines how long a alarm shall be active
A App wich reports Sunrise and sunset were nice, too.
At the moment, i don't see, that razberry is the gateway, wich can act with all devices and is very tricky do configure
