What's needed for me
Franz Winchester
Post by Franz Winchester »
I am using Z-Wave (currently v3.1.1) on a RaspberryPi with Razberry now since 3 years. In some sectores I see improvments, in others not.
Here is my small to-do list:
App:
-should work again. Since months without possibility to access the system
Heating:
-after restart the system must immediately work as scheduled in the climate control, without any assistance from the user
Dashboard:
-every user should be able to create his own sorted list, not depending on other users
Amazon Alexa:
-improve communication. At the moment it*s a gamble
Rules:
-if-then works, but else normally does not work
-time condition for weekdays should be implemented
-you should be able to use conditions in one term more than only once
Alarms (smoke and water):
-it should be possible to assign smoke or water sensors to different sirens and notifications
I would be pleased, if the system is being developped.
Best regards
Thomas
