delayMicroseconds (80) not declared?
samsonbox
Post by samsonbox »
Hello together,
is it possible, that the function "delayMicroseconds" is not implemented? It is mentioned on the reference-page but i get comiler errors, when i try to use it.
Errors:
Arduino: 1.6.5 (Windows 7), Platine: "Z-Wave>ME Z-Uno, Europe, Disabled"
C:\Users\xx\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/compiler build C:\Users\xx\AppData\Local\Temp\build3273354828723812551.tmp/KY-015.cpp -r C:\Users\xx\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\0.6.7 -p C:\Users\xx\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/sdcc/bin/ -o -mmcs51 --out-fmt-ihx --model-large --verbose --debug --use-stdout --code-loc 0x8000 --xram-loc 0x3000
ab64e9d048c79431b4af475b0225eeea.c:36: warning 88: cast of LITERAL value to 'generic' pointer
from type 'const-char literal'
  to type 'const-char generic* fixed'
ab64e9d048c79431b4af475b0225eeea.c:40: warning 88: cast of LITERAL value to 'generic' pointer
ab64e9d048c79431b4af475b0225eeea.c:74: warning 112: function 'delayMicroseconds' implicit declaration
KY-015.ino:55:1:error: too many parameters
ab64e9d048c79431b4af475b0225eeea.c:90: warning 88: cast of LITERAL value to 'generic' pointer
too many parameters
Thank you for your answers and best regardes
Philipp
Re: delayMicroseconds (80) not declared?
It is implemented only in the lates 2.0.5 branch. It is in test bed now, but will become release next week.
Please look on our site in news how to pick up 2.0.5 from test bed.
