It can be a problem if the value is going out of the needed range - that's why I have changed the procedure for measure the values.
If you see such "spikes" and want to eleminate it - you can use the statistical "median" method.
Get (as sample) 5 values, sort it and take the middle of them. Spikes will be outsorted.
Here is a sample code for 5 readings - maybe it is useful for somebody
It's easy to modify the code for other needs.
static const byte adc[] = {A0,A1,A2,A3};
vA0 = vADC(0);
vA1 = vADC(1);
vA2 = vADC(2);
vA3 = vADC(3);
word vADC(word adcNum){
// use odd number of readings 5,7,9,....
word vAD[5];
for(int n=0; n<5; n++){
vAD[n]=analogRead(adc[adcNum]);
return Median(vAD,5);
word Median(word *AS1, byte len) {
byte m;
byte n=len;
word temp=0;
do {
m=1;
for(int p=1;p<len;p++){
if(AS1[p-1]>AS1[p]){
temp=AS1[p];
AS1[p]=AS1[p-1];
AS1[p-1]=temp;
m=p;
n=m;
} while(n>1);
n=(int)(len/2);
return AS1[n];
