Compilation problems
pjpankhurst
Post by pjpankhurst »
Hi
I've been trying to build some of the Arduino example files, in particular Examples->LiquidCrystal->HelloWorld
The code builds just fine when I select the Board to be an Arduino, however when I select a z-uno board it fails to compile
The error I get is:
Preprocessing file: _HelloWorld.cpp with SDCPP...
HelloWorld.ino:44:27: fatal error: LiquidCrystal.h: No such file or directory
compilation terminated.
Clearly the header file and library are there, so I'm confused as to why it throws this error.
Any suggestions what the issue is here?
Cheers
Paul
Re: Compilation problems
You have to move all Z-Uno specific libraries on the Z-Uno folder: please have a look on http://z-uno.z-wave.me/getting-started/ ... uinoFolder
pjpankhurst
Thanks for the answer, only just seen the reply, but had worked out that was the problem :-)
SergioP
Post by SergioP »
Hi pjpankhurst, PoltoS,
could you please provide some more details on what you did to solve this problem?
Sergio
Investigating for fun. Trying more confortable DIY home appliances
Move your library in the Z-Uno folder
