from the brochure I can see that the new gen Z-uno has 3 UART ports. Are they similar to the one that z-uno gen 1 has or do they possess more capabilities? for example the ability to use parity bits and 2 stop bits.
Release of Z.Uno - Gen7
Re: Release of Z.Uno - Gen7
Any update on dispatching?
@Poltos: any update on my post from June 30th? I would like to know before we start designing the PCB, to see either we use an SPI to UART converter or not. Thanks
Any details on the new module? When will you have a form factor available for PCB design?
The design is almost stabilized, we are doing final checks before producing them. Once checked, we will update the datasheet and make it public.
BTW, this time we are doing three different versions of the module with different antenna connection: u.fl, pin and hole (for a wire) design. Which one will be the most interesting for you?
I was quite excited to have just received new ZUNO HW version from my electronics shop today. I have been holding off couple of my projects till this moment.
What I received "ZME_ZUNO2" on the box, but I cannot read anything about its release on the forum here.
The PCB has "Z-Uno 2 rev. 6" on it.
Yet I cannot access any of the links in the documentation. e.g. :
https://z-uno.z-wave.me/arduino-install
What is it for a version I have - is it an official release?
How come the webpages from documentation are not accessible?
Thanks,
Pavel
Thanks,
Pavel
Sorry, docs is appearing step by step.
Please read this meanwhile: https://help.z-wave.me/en/knowledge_bas ... nvironment
Thanks for help, now I can connect and upload.
So far everything works, time to start experimenting with sketches
For module the version with the u.fl connector is the one I would use.
