I'm reading power meter data from my power meter (RJ12 P1 port). The meter sends data every 10 seconds.
I however think that I lose packets (dropped packets). Data is received at baud rate 115200. I have a feeling that Z-Uno are unable to keep up reading data from the Rx-buffer before it is overwritten..
Every burst of data is approximately 500-1000 bytes. Is there any way to increase the UART Rx buffer?
This is my code.
#define DEBUG 1 // 1=On, 0=Off
char incomingByte = 0; // for incoming serial data
int numberOfByte = 0; // count number of bytes received
char buffer[500];
void setup()
#ifdef DEBUG
Serial.begin();
Serial.println("Inside setup");
#endif
Serial1.begin(115200);
void loop()
//delay(100); //sleep 1s
while (Serial1.available() > 0)
// read the incoming byte:
incomingByte = (char)Serial1.read();
buffer[numberOfByte] = incomingByte & 127;
numberOfByte++;
if (numberOfByte > 0)
Serial.println("");
Serial.print(numberOfByte, DEC);
Serial.println(":RECEIVE:");
for (int i=0; i<numberOfByte; i++)
//Serial.print(buffer);
Serial.print(buffer[i]);
numberOfByte = 0; //reset
//Serial1.flush();
