Question about zunoSendReport
sdtlee
Post by sdtlee »
Hi everyone,
I have a question about zunoSendReport.
My goal is the measure the RSSI of the signal send out from Z-Uno.
What I try to do is, when the user press the service button, I will try to send out a signal, so that the usb sniffer can capture the signal and show the RSSI.
Here is the code I modified from sample code:
#include "Arduino.h"
#include "ZUNO_Buttons.h"
#define MY_SERIAL Serial0
#define BUTTON		23
uint8_t dimmerValue = 0;
// the setup function runs once, when you press reset or power the board
void setup() {
  MY_SERIAL.begin();
  MY_SERIAL.println("Setup");
  pinMode(LED_BUILTIN, OUTPUT);
  Btn.addButton(BUTTON);
// the loop function runs over and over again forever
void loop() {
  process_buttons();
  MY_SERIAL.println("Loop");
void process_buttons() {
  if (Btn.isSingleClick(BUTTON)) {
    MY_SERIAL.println("isSingleClick");
    zunoSendReport(1);
    if (dimmerValue == 0)
      digitalWrite(LED_BUILTIN, HIGH);
      dimmerValue = 1;
    else
      digitalWrite(LED_BUILTIN, LOW);
      dimmerValue = 0;
I use Z-Wave Zniffer to see the signal like this.
I expect it will show a new data when I press the button but it does not.
However I can see the Explorer Autoinclusion appears.
Anyone can give me some hints?
Thank you in advance.
Regards,
Lee
Regards,
Lee
Re: Question about zunoSendReport
Hello!
1) No channels in your sketch, so no reports. Also, note that some report types are never sent more often than 30 seconds.
2) Better use zunoSendNIF() - it will use 40 kbps
3) A good news for you is that the new version of Z-Uno 2 (and RaZberry 7) will allow sending any packet and will work as Zniffer. We will launch this extension in two weeks. So your task will be easily solved (more info here https://z-wave.me/products/zniffer/)
sdtlee
Post by sdtlee »
Hi PoltoS,
Thank you very much for your reply.
I tried zunoSendNIF() and I can see the signal through the Zniffer USB.
Here is the sample code for anyone who need in the future.
#include "ZUNO_Definitions.h"
#define BUTTON		23
void setup() {
  MY_SERIAL.begin();
void loop() {
  process_buttons();
    zunoSendNIF();
      dimmerValue = 1;
    else
      dimmerValue = 0;
Regards,
Lee
