Is there a Library available for using a Real Time Clock shield
Steve_Elves
Post by Steve_Elves »
I'd like to use a RTC for accurate timestamping of pulses from a rain gauge that I am building. Has anyone come across a library that works with the ZUNO for this purpose?
The RTC I'm looking to use is a PCF8563.
Re: Is there a Library available for using a Real Time Clock shield
It might be enough to use Clock command class and use internal timer. Clock has to be implemented in Z-Uno 2, but it is rather simple
Steve_Elves
Thanks for the reply and suggestion!
I would prefer to use a dedicated RTC module, because it will retain its settings and keep time even if there is a power interruption. I also believe that the RTC modules will be slightly more accurate, although for the purposes of this application, extreme accuracy is not required.
KGBEl
Post by KGBEl »
PoltoS, there is a library for DS3231 & DS3232 called ZUNO_DallasRTC.
Isn't it possible to use ZUNO_DallasRTC to work with Z-Uno V2?
If not, what has to be done to make it work with Z-Uno v2?
At the first glance it looks compatible. We will check it, but you can also try on your sidee
KGBEl
Post by KGBEl »
Thanks for answer.
I’m waiting for my rtc-order to arrive, after that that I’ll come back.
