Z-Uno service leds?
KGBEl
Z-Uno service leds?
Post by KGBEl »
I’m new to this and just uploaded my first sketch, 5 DS18B20 for reading temperature.
Compiling and uploading works fine and even inclusion to my controller worked, but nothing more. I found that the green led blinks almost stable, until it stops for short and the red led starts, this one blinks a couple of times and then the green one starts over again. This runs over and over again. What should I understand from the two leds behaviour?
Is there some documentation of these service leds?
Re: Z-Uno service leds?
Are you sure you have not "pressed" the button by connecting button/int pins to ground? Looks like the button pin is always connected to ground
KGBEl
Post by KGBEl »
I found another topic where same problem was described and found out that the blinking red led, blinks
beccause the program resets itself due to stack owerflow. I missed N_SENSOR (number of sensors) in: byte addresses[ADDR_SIZE * N_SENSOR];
Thank you for your answer.
