Could you please advice, facing an issue on Meter Electric channel with PowerFactor scale. After inclusion, interview not pass and no value comes from that channel.
Checked other scaling KHW, KVAH and Pulsecount are OK, but on Amps, Volts and PowerFactor issue observed.
Tested on 3.0.9 beta and with new 3.0.10. Please find below details and minimized code to reproduce the issue:
More info:
Z-Uno2 bootloader version:3.0.10 (release version)
Security:S2
Frequency:EU
Device included:yes
Device included securely by controller:yes
Controller:RaZberry7 - 7.28 / Z-Way - 4.0.2 [/list]
Code: /minimized one channel only/
ZUNO_SETUP_CHANNELS(
ZUNO_METER(
ZUNO_METER_TYPE_ELECTRIC,
METER_RESET_DISABLE,
ZUNO_METER_ELECTRIC_SCALE_POWERFACTOR,
METER_SIZE_TWO_BYTES,
METER_PRECISION_TWO_DECIMALS,
getterPowerFactor,
resetterPowerFactor
word PowerFactor = 0;
void setup() {
PowerFactor = 1;
void loop() {
word getterPowerFactor() {
return PowerFactor;
void resetterPowerFactor(byte value) {
}Code: Select all
FIRMWARE
VERSION: 03.10
BUILD_SEQUENCE: 00001842
BUILD_DATETIME: 2023-01-17T17:38:12(MSK)
SUPPORTED_HWREV: 0704
LIMITS
CODE: 178176 Bytes
RAM: 16384 Bytes
HARDWARE
CHIP_UID: 84 2E 14 FF FE 6A 28 08
PROD_TIME: 2021-07-07T20:41:25(MSK)
PROD_SN: 213
LOCK: DBG_LOCKED
ZWay - img2
Thanks,
