[solution] Error sketch upload: "Sketch was compiled for another board revision"
element
Post by element »
For testing, I used the default sketch:
void setup() {
  // put your setup code here, to run once:
void loop() {
  // put your main code here, to run repeatedly:
and firmware board Z-Uno2 version 3.0.12 beta.
If the compilation was successful. However, an error appears during sketch upload:
Error  0	 Sketch was compiled for another board revision:656e (Expected:0704). Try to recompile the sketch.
Failed uploading: uploading error: exit status 7
Decrease the file name (or file path) and try sketch upload again.
Regards
Re: [solution] Error sketch upload: "Sketch was compiled for another board revision"
There are no revisions 656e. This looks like a board issue. Try to upgrade the bootloader then firmware and then check if it works
element
Post by element »
PoltoS wrote:
01 Jun 2024 12:13
But I have already solved the problem and here is the solution.
