Hi, I will order one and try.
Where can I find info about how to connect to Z-Uno?
Will I use only 3.3V or both?
Is there a Library available for using a Real Time Clock shield
Re: Is there a Library available for using a Real Time Clock shield
I mean, on the CP2102, will I use only 3.3V or both 3.3 and 5V.
Sorry for this inconvenience.
After changing the code a bit it worked just fine.
and made this output:
Is that what you wanted?
#include "Arduino.h"
//#include "Wire.h"
#include <ZUNO_DS3232RTC.h>
#include <Time.h>
#define MY_SERIAL Serial
DS3232RTC myRTC;
tmElements_t te, te_r;
time_t ts; // secs since 1900.
void setup() {
MY_SERIAL.begin(9600);
te.Second = 30;
te.Minute = 32;
te.Hour = 13;
te.Wday = 6;
te.Day = 8;
te.Month = 6-1;
te.Year = 2024 -1900;
myRTC.write(&te);
void loop() {
if (myRTC.read(&te_r) != 0 /*WIRE_ERORR_TRANSMISSION_SUCCESS*/) {
MY_SERIAL.print("myRTC.read - error\n");
disp();
delay(10000);
void disp(void){
MY_SERIAL.print("dump: ");
MY_SERIAL.dumpPrint(&te_r, sizeof(te_r), sizeof(te_r));
MY_SERIAL.printf("\n*************\n%04d-%02d-%02d %02d:%02d:%02d : Weekday = %d.\n", te_r.Year + 1900, te_r.Month + 1, te_r.Day, te_r.Hour, te_r.Minute, te_r.Second, te_r.Wday);
�myRTC.read - error
dump: 1E 20 0D 06 08 05 7C
2024-06-08 13:32:30 : Weekday = 6.
myRTC.read - error
dump: 28 20 0D 06 08 05 7C
2024-06-08 13:32:40 : Weekday = 6.
myRTC.read - error
dump: 32 20 0D 06 08 05 7C
2024-06-08 13:32:50 : Weekday = 6.
dump: 00 21 0D 06 08 05 7C
2024-06-08 13:33:00 : Weekday = 6.
myRTC.read - error
dump: 2B 0D 06 00 05 0E 7C
2024-15-05 06:13:43 : Weekday = 0.
myRTC.read - error
dump: 35 0D 06 00 05 0E 7C
Is it what you asked for?
