Help! Pairing mode not working any more...
michap
Re: Help! Pairing mode not working any more...
Post by michap »
PoltoS wrote:USA model of Z-Uno? It does not exist yet ;)
EU model will work perfectly for Malaysia.
As was already discussed above.
Michael
Z-Uno for USA was release today. You can order yours on https://z-uno.us
ALittleSlow
Post by ALittleSlow »
maxhill wrote:
23 Oct 2016 03:03
Never mind. Didn't see that it was on Russian frequency in Arduino IDE, so my sketch build was the wrong frequency. Changed it to EU and I can confirm simple dimmer to be working
I had the exact same problem, though my controller is a Homeseer Hometroller Zee S2. Setting the frequency should be included in the guides.
Good point. We will add this
haus
Post by haus »
I have a z-uno purchase from https://z-uno.us and can not get the z-uno to join my SmartThings hub. The z-uno has never been connected to my hub. Using an example sketch under basics called blink. The Frequency is set to USA. I have tried pushing the z-uno button 3 times and resetting with a 5 second hold of the button. Nothing seems to help! The hub is about 5 meters away from the z-uno device. Suggestions?
First try to bring it closer.
Then try the Rescue mode.
http://z-uno.z-wave.me/getting-started/ ... ntIncludeZ
haus
Post by haus »
Bring the z-uno close to the Smartthing hub and rescue did not help.
This what my SmartThing hub logs
No devices to add, verified devices: [:]
Is there any indication that the z-uno is attempting to be included into a hub? Or do you have another suggestion?
It should blink with red when you click three times
haus
Post by haus »
Thank you! I was not pressing the service button 3 times fast enough. The z-uno is now included on my SmartThings hub.
Now US version of Z-Uno is available from https://z-uno.us
