FLIRS ISSUE
blooby
FLIRS ISSUE
Post by blooby »
My sketch is work on normal mode (ZUNO_SLEEPING_MODE_ALWAYS_AWAKE), but not in FLiRs mode (ZUNO_SLEEPING_MODE_FREQUENTLY_AWAKE)
//motor A connected between A01 and A02
#define STBY 10
#define PWMA 12 //pwm seem don't work
#define AIN1 9
#define AIN2 11
// variable to store current relay state
byte lastSetValue;
byte var1;
byte var2;
byte state;
byte change;
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_BINARY(getter, setter));
// next macro sets up the sleeping mode
// device will wake up by user request and regulary listening for packets
//ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_FREQUENTLY_AWAKE);
// the setup routine runs once when you press reset:
void setup(){
 pinMode(STBY, OUTPUT);
 pinMode(PWMA, OUTPUT);
 pinMode(AIN1, OUTPUT);
 pinMode(AIN2, OUTPUT);
 state=0;
 change=0;
 var1=0;
 var2=0;
void loop(){
  if (change == 1) {
    if (state == 0) {
      // Turn OFF
      digitalWrite(STBY, HIGH); //disable standby
      digitalWrite(AIN1, HIGH);
     digitalWrite(AIN2, LOW);
     //analogWrite(PWMA, 254);
      digitalWrite(PWMA, HIGH);
      //delay(150);
     if (var1 > 200) {
      var1=0;
      var2=0;
      digitalWrite(STBY, LOW); //enable standby
      change=0;
      // this function sends the device into sleep
      //zunoSendDeviceToSleep();
     var1++;
    else
      // Turn ON
      digitalWrite(AIN1, LOW);
      digitalWrite(AIN2, HIGH);
      //delay(500); //go for 1 second
      if (var2 > 200) {
      var1=0;
      var2=0;
      change=0;
      var2++;
byte getter() {
  return lastSetValue;
void setter(byte newValue) {
  // newValue is a variable, holding a "value"
  // which came from the controller or other Z-Wave device
  if (newValue > 0) { // if greater then zero
    state=1;
    change=1;
  else {            // if equals zero
    state=0;
    change=1;
  // save the new value in a variable
  lastSetValue = newValue;
Thanks for your help.
Re: FLIRS ISSUE
Hello!
Unfortunatelly ZUNO_SWITCH_BINARY is not allowed in ZUNO_SLEEPING_MODE_FREQUENTLY_AWAKE mode due to Z-Wave certification. We are working with Z-Wave Alliance to officially allow it, meanwhile will add a parameter to disable this restriction.
blooby
Re: FLIRS ISSUE
Post by blooby »
Thanks for your answer.
Do you have a delay ?
How can i upgrade it after your add this one ?
Re: FLIRS ISSUE
Hello! This feature will become available in 2.0.7 - around mid/end of October. These weekends we will release 2.0.6
To upgrade you need to go to board manager, download updates (select newer version) and then use Burn bootloader menu item to upgrade your Z-Uno to the latest version
affanalhakam
Re: FLIRS ISSUE
Post by affanalhakam »
Hello...
I went to board manager, but i didn't find any newer version in the option, it shows 0.6.7 as the last version. Should I change the URL of additional board manager? If so, can you please share the URL? thank you in advance.
wukong
Re: FLIRS ISSUE
Post by wukong »
PoltoS wrote:Hello! This feature will become available in 2.0.7 - around mid/end of October. These weekends we will release 2.0.6
Is the feature to allow ZUNO_SWITCH_BINARY in ZUNO_SLEEPING_MODE_FREQUENTLY_AWAKE mode available already?
Thanks.
blooby
Re: FLIRS ISSUE
Post by blooby »
I try to make this sample working without success :
https://z-uno.z-wave.me/examples/FLiRSSimpleSwitch/
// LED pin number
// 13 pin - user LED of Z-Uno board
#define LED_PIN 13
// Last saved LED value
byte currentLEDValue;
void setup() {
  pinMode(LED_PIN, OUTPUT); // setup pin as output
// the loop routine runs over and over again forever:
void loop() {
void setter(byte value) {
  // value is a variable, holding a "new value"
  if (value > 0) {               // if greater then zero
    digitalWrite (LED_PIN, HIGH); //turn the LED on (HIGH is the voltage level)
  } else {                         // if equals zero
    digitalWrite(LED_PIN, LOW);   //turn the LED off by making the voltage LOW
  // we'll save our value for the situation, when the controller will ask us about it
  currentLEDValue = value;
byte getter() {
  return currentLEDValue;
Somebody use FLIRS mode ?
Re: FLIRS ISSUE
We will fix FLiRS by mid June or earlier.
Re: FLIRS ISSUE
Z-Uno software 2.1.0 is released with support for FLiRS capable channels: Siren and Valve control
