Page 1 of 2
GPIO inputs without pullup (HiZ) problem
Posted: 09 Oct 2016 19:31
by g-knight
I need to use Hi impedance digital inputs. I connected the input pin through a resistor divider using 100 K / 150 K. My input before the divider varies from 0 to 4.9 V. So output is expected to be between 0 & 2.95 V.
I used the following code:
#define PIR_PIN 9
pinMode(PIR_PIN, INPUT);
pirState = digitalRead(PIR_PIN);
Unfortunately, this always report logical one value.
I measured with a multi-meter, and noticed that voltage on Z-Uno pin doesn't follow the divider output and seems to be constrained as if an internal pull-up were still enabled despite the "INPUT" used, and NOT "INPUT_PULLUP".
I also tried with an analog input pin 6 / ADC3, but it's the same.
A work around I found is using the analog way:
int val = analogRead(A3);
if (val > 500)
pirState = HIGH;
else
pirState = LOW;
Is there a bug in the pinMode library?
Gerard
Re: GPIO inputs without pullup (HiZ) problem
Posted: 09 Oct 2016 21:13
by A.Harrenberg
if you disconnect the divider from the Z-Uno and measure again, is the voltage 0 and 2.95V as expected?
The 100/150 kOhm seems also a little high, you might want to try lower values, but that depends also on the what source is connected to the divider.
Andreas.
Posted: 09 Oct 2016 21:35
by g-knight
Yes, if I disconnect the divider, I have around 0 and 2.95V as expected.
I don't think 100/150 K is so much, given the documentation:
"Pins configured as INPUT make extremely small demands on the circuit that they are sampling, equivalent to a series resistor of 100 MΩ in front of the pin. This makes them useful for reading a sensor."
I'm wondering if there isn't a bug in the low level firmware that manages the GPIO in the SOC.
But, it's strange that it's not been discovered before... So, did I do something wrong?
Gerard
Posted: 09 Oct 2016 22:22
The chip need some current to detect the voltage. Usually it is about 10 μA as stated here:
http://z-uno.z-wave.me/technical/
10 μA at 3 V gives 300 kΩ - this is the limit for Z-Uno to detect correctly input voltage. 100-150 kΩ should still be ok.
Please chekc other pins too (not 9-16). May be there is a problem with 9-16 (they are a bit different from others)
Posted: 09 Oct 2016 23:03
by g-knight
I tried with pin 22 and it doesn't work better. Looks the same...
After having programmed
#define PIR_PIN 22
I measured voltage with the pin left unconnected. I got about 3V (so, not floating), and if connect it to ground with ampere meter, it draws 64 µA. More than 6 times from what is written at
http://z-uno.z-wave.me/technical/ and far from the 100 MΩ found in doc (
https://z-uno.z-wave.me/Reference/INPUT/).
Sure the PULLUP is de-activated?
Gerard
Posted: 10 Oct 2016 00:21
Can you try with 47 kΩ? We took these data from the doc of the chip, have not measured it in more details.
Posted: 10 Oct 2016 01:05
are you sure your sensor have low output resistance? If it is an MCU (like PIR sensor), it's output R is about 100k itself. In that case use a dividor with arms 2k/1k. Looks like there is not enough current for Z-Uno to detect it.
Posted: 10 Oct 2016 09:35
by g-knight
No I can't use lower resistances, I really need high impedance.
For the PIR, I don't use something based on a microcontroller, it's a standard flood projector with discrete components, and I don't want to disturb its internal logic.
I'm pretty sure that's the pull-up is still enabled in the chip when using the "INPUT" parameter. Can't you check that point?
As I noticed the same behavior with ADCx inputs, I guess that sooner or later there will be troubles with measuring analog value having high impedance output.
Thank you.
Gerard
Posted: 16 Oct 2016 22:39
by g-knight
Hi PoltoS,
Is there any chance that someone in the Z-Uno project team at Z-Wave.Me has a look into this topic?
The value I measured shows an internal impedance of approximately 50 K Ohms, which is typical from microcontrollers' internal pull-up nowadays.
To solve this problem, I changed my circuit and added an op amp in front of the Z-Uno (a LM 324), but in my opinion it's a waste since if the pull up could be removed, the chipset is most probably having MOS inputs with high impedance.
I tried to find datasheet for Mitsumi WML-C85 or Sigma Designs ZM5101 (which the Mitsumi WML-C85 seems to be a second source), but without success. It seems that this part is closed source (I mean manufacturers aren't willing to share information).
Gerard
Posted: 18 Oct 2016 13:30
by p0lyg0n1
Hi, Gerard. I try it and will post results here. The normal value of pull-up have to be about 20 KOhms.
