Adding classes?
Kronsson
Adding classes?
Post by Kronsson »
Is it possible to add user defined classes?
I've tried with very basic examples that works with "Arduino classic" but cannot get the Z-UNO compiler to accept it.
One of the classes I want use is the attached elapsedMillis.h
Reference:
http://playground.arduino.cc/Code/ElapsedMillis
Could someone show how to successfully use this it would be very appreciated.
/* Elapsed time types - for easy-to-use measurements of elapsed time
 * http://www.pjrc.com/teensy/
 * Copyright (c) 2011 PJRC.COM, LLC
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
#ifndef elapsedMillis_h
#define elapsedMillis_h
#ifdef __cplusplus
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class elapsedMillis
private:
	unsigned long ms;
public:
	elapsedMillis(void) { ms = millis(); }
	elapsedMillis(unsigned long val) { ms = millis() - val; }
	elapsedMillis(const elapsedMillis &orig) { ms = orig.ms; }
	operator unsigned long () const { return millis() - ms; }
	elapsedMillis & operator = (const elapsedMillis &rhs) { ms = rhs.ms; return *this; }
	elapsedMillis & operator = (unsigned long val) { ms = millis() - val; return *this; }
	elapsedMillis & operator -= (unsigned long val)      { ms += val ; return *this; }
	elapsedMillis & operator += (unsigned long val)      { ms -= val ; return *this; }
	elapsedMillis operator - (int val) const           { elapsedMillis r(*this); r.ms += val; return r; }
	elapsedMillis operator - (unsigned int val) const  { elapsedMillis r(*this); r.ms += val; return r; }
	elapsedMillis operator - (long val) const          { elapsedMillis r(*this); r.ms += val; return r; }
	elapsedMillis operator - (unsigned long val) const { elapsedMillis r(*this); r.ms += val; return r; }
	elapsedMillis operator + (int val) const           { elapsedMillis r(*this); r.ms -= val; return r; }
	elapsedMillis operator + (unsigned int val) const  { elapsedMillis r(*this); r.ms -= val; return r; }
	elapsedMillis operator + (long val) const          { elapsedMillis r(*this); r.ms -= val; return r; }
	elapsedMillis operator + (unsigned long val) const { elapsedMillis r(*this); r.ms -= val; return r; }
class elapsedMicros
private:
	unsigned long us;
public:
	elapsedMicros(void) { us = micros(); }
	elapsedMicros(unsigned long val) { us = micros() - val; }
	elapsedMicros(const elapsedMicros &orig) { us = orig.us; }
	operator unsigned long () const { return micros() - us; }
	elapsedMicros & operator = (const elapsedMicros &rhs) { us = rhs.us; return *this; }
	elapsedMicros & operator = (unsigned long val) { us = micros() - val; return *this; }
	elapsedMicros & operator -= (unsigned long val)      { us += val ; return *this; }
	elapsedMicros & operator += (unsigned long val)      { us -= val ; return *this; }
	elapsedMicros operator - (int val) const           { elapsedMicros r(*this); r.us += val; return r; }
	elapsedMicros operator - (unsigned int val) const  { elapsedMicros r(*this); r.us += val; return r; }
	elapsedMicros operator - (long val) const          { elapsedMicros r(*this); r.us += val; return r; }
	elapsedMicros operator - (unsigned long val) const { elapsedMicros r(*this); r.us += val; return r; }
	elapsedMicros operator + (int val) const           { elapsedMicros r(*this); r.us -= val; return r; }
	elapsedMicros operator + (unsigned int val) const  { elapsedMicros r(*this); r.us -= val; return r; }
	elapsedMicros operator + (long val) const          { elapsedMicros r(*this); r.us -= val; return r; }
	elapsedMicros operator + (unsigned long val) const { elapsedMicros r(*this); r.us -= val; return r; }
#endif // __cplusplus
#endif // elapsedMillis_h
/J
Re: Adding classes?
You have to place it in the same folder as the Z-Uno libs are.
The lib loos pretty ok, but not sure Z-Uno compiler do support operators redefinition. Need to ask developers.
