Hi there, is it possible to set up a ZUno with - let's say 4 Temperature sensors and display those values within ZWay ? As I'm new to ZUno and not the programming crack - any help hardware- and software wise would be appreciated.
Thank you!
Multi-temp device
Re: Multi-temp device
FWIW: It is cheaper to deploy a Fibaro Universal sensor (4 temp sensors, 2 binary) for 40 EURO. (Seems not to be available in the USA)
Yes, it is possible. Using 1-wire you can connect many DS18B20 sensors. Using analog sensors you can use up to 4.
I think you can use more than 4 Analog sensors. If you want to do fully analog: use a series of relays which are switched by the GPIOs. As long as you have enough GPIOs there is no limit for analog sensors.
This may be true if you do not want to create a battery powered device.pz1 wrote:It is cheaper to deploy a Fibaro Universal sensor (4 temp sensors, 2 binary) for 40 EURO. (Seems not to be available in the USA)
I also would suggest to use 18B20 or I²C sensors - of course analog is possible as described.
Michael
Hi, as "pz1" already mentioned it seems to be easier and cheaper to use a Fibaro Universal Sensor...anyway, thanks for your replies.
