Error in <string.h>: Typedef redefinition with different typ
droll
Post by droll »
The include file 'string.h' that is provided with the Z-Uno (version 2.0.6 and 2.0.7) contains the following type definition:
typedef unsigned int size_t;
After including <string.h> into my program the compilation generates the following error:
error:typedef redefinition with different types ('unsigned int' vs 'unsigned short')
Since my program is not defining the size_t type I guess this type is defined by default by the compiler, and string.h is redefining it differently.
So the string.h include file that is provided with the Z-Uno package seems be incompatible with the compiler.
droll
Re: Error in <string.h>: Typedef redefinition with different
Post by droll »
Well, I found the second place where size_t is defined:
File 'ArduinoTypes.h':
typedef unsigned short size_t;
File 'string.h':
p0lyg0n1
Post by p0lyg0n1 »
We didn't use string.h in our projects yet. You can try to add string.h to your code and replace our defenition of size_t to its definition in string.h.
