Battery level definition
michap
Post by michap »
how the battery level is defined?
I mean - is it linear? So 3.3V = 100%, 2.97V=90% and 2.475V = 75% ?
I think that not :)
Maybe linear between 2.4V (0%) and 3.3V (100%)?
Would be interesting to know for battery powered devices.
Michael
Re: Battery level definition
Battery level is the amount of energy remaining in the battery. It is defined in Wh. As an indication of the energy battery producers sometimes provide discharge curves that displays the amount of energy against voltage. This curve does have a sigmoid form.
My observation with Zwave devices are quite diverse patterns. Some of my StellaZ TRV's continued to work for well over six weeks at 0% charge, while others stopped at 10% or even more.
I guess it strongly depends on the place where the device sits. Heating systems are not designed with control with RF in mind. TRV's are stowed away in odd corners. Unfortunately you can no longer inspect the timing info in ExpertUI. But in the past I found a strong correlation between battery drain and bad figures in the timing!
michap
Post by michap »
Right. I have same experience....
That's why interesting for me how it will be defined in Z-Uno.
Here is no "battery type" defined, so that we can not take any "discharge curves".
So there are 2 questions - first about level definition itself, and second when (in what state) the actual battery level will be defined (idle process, while sending,....)
Michael
The only way to measure battery level is via currnet Vcc voltage. But most of modern batteries do have a pretty flat curve that drops sharply on the end of battery life. This makes it pretty hard to covert Vcc -> % of energy remained.
Usually we do linear 100%-0% via 3.0V-2.4V mapping. But as you expect, this is far from real % of energy. Indeed, manu devices can work when 0% is shown for a year.
