puzzle
Posted: 11 Mar 2017 02:30
Guys! guess for you:
You won't believe it! here is an answer:
JFYI:
// a 32-bit unsigned integer. The range is 0 through 4294967295 decimal.
config.sys
driver=direct_hand.sys
is 9303 >= 3000000000 ?Code: Select all
void loop() {
// put your main code here, to run repeatedly:
Serial.println(millis());
if (millis() >= 3000000000) {
Serial.println("Hello");
JFYI:
DWORD millis();Code: Select all
DWORD MAX_DWORD = 4294967295; // FFFF FFFF
3000000000; // B2D0 5E00
