first_sketch_line
janjoh
first_sketch_line
Post by janjoh »
So, I have found this error on the forum, but cannot find how it relates to my simple sketch. Any help
#include "Wire.h"
#include "ZUNO_DS18B20.h"
#define FAN1_PWM_PIN 13
#define FAN1_ENABLE_PIN 26
s_pin FAN1_TACH_PIN = 9;
#define FAN2_PWM_PIN 22
#define FAN2_ENABLE_PIN 27
s_pin FAN2_TACH_PIN = 10;
#define MOSFET1_PWM_PIN 20
#define ONE_WIRE1_PIN 11
#define ONE_WIRE2_PIN 12
ZUNO_SETUP_CHANNELS(
   ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                          SENSOR_MULTILEVEL_SCALE_CELSIUS,
                          SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL,
                          temp1getter)
void setup() {
  pinMode(FAN1_ENABLE_PIN, OUTPUT);
  pinMode(FAN1_PWM_PIN, OUTPUT);
  pinMode(FAN1_TACH_PIN, INPUT_PULLUP);
  pinMode(FAN2_ENABLE_PIN, OUTPUT);
  pinMode(FAN2_PWM_PIN, OUTPUT);
  pinMode(FAN2_TACH_PIN, INPUT_PULLUP);
  pinMode(MOSFET1_PWM_PIN, OUTPUT);
  Serial.begin(9600);
  digitalWrite(FAN1_ENABLE_PIN, LOW);
  analogWrite(FAN1_PWM_PIN, 0);
  digitalWrite(FAN2_ENABLE_PIN, LOW);
  analogWrite(FAN2_PWM_PIN, 0);
  analogWrite(MOSFET1_PWM_PIN, 0);
  delay(10000);
void loop() {
digitalWrite(FAN1_ENABLE_PIN, HIGH);
 analogWrite(FAN1_PWM_PIN, 10);
 delay(10000);
 analogWrite(FAN1_PWM_PIN, 50);
 delay(10000);
 analogWrite(FAN1_PWM_PIN, 128);
 delay(10000);
 analogWrite(FAN1_PWM_PIN, 255);
 delay(10000);
word temp1getter() {
  //NoOp
Using library ZUNO_DS18B20 in folder: C:\Users\j2\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.8\libraries\ZUNO_DS18B20 (legacy)
C:\Users\j2\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.30/zuno_toolchain/compiler build C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp/TVBankController.cpp -r C:\Users\j2\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.8
Exception:'first_sketch_line'
(<type 'exceptions.KeyError'>, '<string>', 205)
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\Print.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\Print_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\Stream.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\Stream_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\Wire.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\Wire_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\HLCore.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\HLCore_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\HardwareSerial.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\HardwareSerial_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\ZUNO_OneWire.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\ZUNO_OneWire_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\ZUNO_DS18B20.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\ZUNO_DS18B20_sdcpp_.cpp ...
Preprocessing file: C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\_TVBankController.cpp with SDCPP...
Compiling C:\Users\j2\AppData\Local\Temp\build8887622240629786535.tmp\_TVBankController_sdcpp_.cpp ...
TVBankController.ino:61:1:warning:control reaches end of non-void functionTraceback (most recent call last):
File "<string>", line 205, in buildFunc
File "C:\tmp\zuno-packager\build\zuno_toolchain-00.08.30-win32\build\compiler\out00-PYZ.pyz\uCxx", line 5473, in compileArduinoSketch
File "C:\tmp\zuno-packager\build\zuno_toolchain-00.08.30-win32\build\compiler\out00-PYZ.pyz\uCxx", line 5206, in compileCPPPhase
File "C:\tmp\zuno-packager\build\zuno_toolchain-00.08.30-win32\build\compiler\out00-PYZ.pyz\uCxx", line 5161, in advancedCompileCXX
File "C:\tmp\zuno-packager\build\zuno_toolchain-00.08.30-win32\build\compiler\out00-PYZ.pyz\uCxx", line 4285, in CompileCXX
File "C:\tmp\zuno-packager\build\zuno_toolchain-00.08.30-win32\build\compiler\out00-PYZ.pyz\uCxx", line 4958, in compilerPrintError
KeyError: 'first_sketch_line'
C:\Users\j2\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.30/zuno_toolchain/compiler returned 2
Error compiling.
Re: first_sketch_line
In 2.0.9 (still in tests) we have made a meaningfull error message in this case.
In brief, there is no pin 25 nor 26 in Z-Uno ;)
janjoh
Post by janjoh »
PoltoS wrote:In 2.0.9 (still in tests) we have made a meaningfull error message in this case.
Oh Cr*p.. I used the _physical_ pin numbers, and not the logical ones... *DOH* :)
p0lyg0n1
Post by p0lyg0n1 »
please add return statement to your getters =)
