One DHT22 and a relay
Posted: 28 Mar 2017 22:37
Hi
I think this problem is quite simple to you.
I'm new to z-uno and I cannot figure out this problem.
I have a relay and one DHT22 sensor. But I cannot get my temperatur or humidity to shown in domoticz but in "serial monitor" it shows my realy works like a charm!
What have I done wrong?
This is my code:
This is my code:
#include "ZUNO_DHT.h"
// pin number, where relay is connected
#define RELAY_PIN 12
#define DHTPIN 9
DHT dht(DHTPIN, DHT11);
// variable to store current relay state
byte lastSetValue;
int humidity; // here we will store the humidity
int temperature; // here we will store the temperature
// next macro sets up the Z-Uno channels
ZUNO_SETUP_CHANNELS(
ZUNO_SWITCH_BINARY(getter, setter),
ZUNO_SENSOR_MULTILEVEL_TEMPERATURE(getterTemperature),
ZUNO_SENSOR_MULTILEVEL_HUMIDITY(getterHumidity)
void setup() {
pinMode(RELAY_PIN, OUTPUT); // set up relay pin as output
dht.begin();
Serial.begin();
Serial.println("start");
void loop() {
// loop is empty, because all the control comes over the Z-Wave
// obtaining readings from the sensor DHT
humidity = dht.readHumidity();
temperature = dht.readTemperature();
Serial.print("Humidity = ");
Serial.print(humidity);
Serial.print(" % ");
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" *C");
// send data to channels
zunoSendReport(1);
zunoSendReport(2);
// send every 30 second
delay(30000);
byte getterTemperature() {
return temperature;
byte getterHumidity() {
return humidity;
// function, which returns the previously saved relay value
// this function runs only once the controller asks
byte getter() {
return lastSetValue;
// function, which sets new relay state
// this function runs only once the controller sends new value
void setter(byte newValue) {
// newValue is a variable, holding a "value"
// which came from the controller or other Z-Wave device
if (newValue > 0) { // if greater then zero
digitalWrite(RELAY_PIN, LOW); //turn relay on
} else { // if equals zero
digitalWrite(RELAY_PIN, HIGH); //turn relay off
// save the new value in a variable
lastSetValue = newValue;
