Help with a (probably very easy) button sketch!
Posted: 22 May 2017 17:10
by n0ir
Hi!
I want to build a battery powered wall switch. I want to use the status of the wall switch as a trigger in my controller (Vera) to start scenes. If possible, I would like to use a momentary button instead of a toggle button.
The "Battery powered wall switch" sketch (
https://z-uno.z-wave.me/examples/batter ... ll-switch/) is too complicated, I do not want to use associations.
Could someone please help me find or write a sketch that send the status of a wall switch button to a controller?
The wall switch will be battery powered (2xAA) so some kind of sleep mode function would be appreciated.
Re: Help with a (probably very easy) button sketch!
Posted: 22 May 2017 18:36
by n0ir
Nexa have a 433MHz device caled WBT-912 (Two Channel Transmitter) that can be connected to a wall switch to make a battery powered remote. It's the same thing I want but it uses 433MHz instead of Z-Wave.
Is it possible to build something similar using Z-Uno?
https://translate.google.se/translate?h ... %2Fwbt-912
Posted: 24 May 2017 02:39
by Black Cat
Posted: 31 May 2017 12:00
by n0ir
This sketch seems to control the LED on the Z-Uno using a switch in Vera. I want to control a switch in Vera using a button connected to the Z-Uno.
Posted: 31 May 2017 12:07
Use Associations for that.
Posted: 31 May 2017 19:03
by Geirbakke
Her are an example, !not tested!
#define Button_PIN_1 14 //Button 1
#define Button_PIN_2 15 //Button 2
#define SWITCH_ON 0xff
#define SWITCH_OFF 0
//ZUNO_SETUP_DEBUG_MODE(DEBUG_ON);
// Global variables to store data reported via getters
byte LastButton_state1 = 0; //Button Last State
byte LastButton_state2 = 0; //Button Last State
ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SET_VALUE); // Send Basic Set to association group
// Set up 2 channels
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_BINARY_GENERAL_PURPOSE(getterBTN1),
ZUNO_SENSOR_BINARY_GENERAL_PURPOSE(getterBTN2)
// the setup routine runs once when you press reset:
void setup() {
Serial.begin();
Serial.println("Setup");
pinMode(Door_PIN_2, INPUT_PULLUP); // Set button pin as input
pinMode(Door_PIN_3, INPUT_PULLUP); // Set button pin as input
// the loop routine runs over and over again forever:
void loop() {
byte currentBTN1_State;
byte currentBTN2_State;
currentBTN1 = digitalRead(Button_PIN_1);
if (currentBTN1 != LastButton_state1) {
LastButton_state1 = currentBTN1;
zunoSendReport(1);
currentBTN2 = digitalRead(Button_PIN_2);
if (currentBTN2 != LastButton_state2) {
zunoSendReport(2);
byte getterBTN1(void) {
if (LastButton_state1 == 0) { // if button is pressed
return 0xff; // return "Triggered" state to the controller
} else { // if button is released
return 0; // return "Idle" state to the controller
if (LastButton_state2 == 0) { // if button is pressed
Posted: 12 Jun 2017 08:49
by Black Cat
Yes, I can see what you mean, there is no example of using a button or mechanical switch.
I've just spent the best part of the day trying to cobble something together, but my knowledge is nearly nil. The above example code returns an error, so like yourself I'm back to the drawing board trying to find a simple example to build from.
Posted: 13 Jun 2017 21:47
by vkapadia
@Geirbakke
Just a quick addition, I assume the functions in your code should be getterBTN1 and getterBTN2.
Posted: 20 Jun 2017 08:20
by Black Cat
I returned to this example and have managed to compile it with some changes. I added some definitions and slowly worked through it until it compiled. I'm not sure if the code will work as I'm yet to upload it to Z-UNO.
Here it is if anyone else wants to test it.
#define currentBTN1
#define currentBTN2
void setup() {
Serial.begin();
pinMode(Button_PIN_1, INPUT_PULLUP); // Set button pin as input
pinMode(Button_PIN_2, INPUT_PULLUP); // Set button pin as input
void loop() {
byte currentBTN1_State1;
byte currentBTN2_State2;
currentBTN1_State1 = digitalRead(Button_PIN_1);
if (currentBTN1_State1 != LastButton_state1) {
LastButton_state1 = currentBTN1_State1;
zunoSendReport(1);
currentBTN2_State2 = digitalRead(Button_PIN_2);
if (currentBTN2_State2 != LastButton_state2) {
LastButton_state2 = currentBTN2_State2;
zunoSendReport(2);
byte getterBTN2(void) {
edit:
Included this into HomeSeer, It is not working in it's current form, I'm also not sure why the extra 2 sensor are populating the device?
- Clipboard01.jpg (45.79 KiB) Viewed 25001 times
edit 2:
See
https://github.com/BlackCatControlSystems/Z-UNO
if anyone wants to collaborate on this.
