The #define for ZUNO_SENSOR_MULTILEVEL_TARGET_TEMPERATURE(GETTER) uses ZUNO_SENSOR_MULTILEVEL_TYPE_TARGET_TEMPERATURE, but this is not in the include file.
I notice that the sensor types defined in this file stop at 0x21 (target temp is 0x22), yet the standard defines them up as far as 0x44.
Is there a reason that the others are missing? Are these useable?
Missing definitions in zuno_definitions.h
Re: Missing definitions in zuno_definitions.h
When we filled those constants last time it was up to 0x21
You can add yours or even contribute to our github
Z-Uno do not care about the value itself and just passes it further to the RF layer, so you can use any value defined in the standard.
petergebruers
I've got one too:
#define SENSOR_MULTILEVEL_SCALE_MILLIVOLT 0x01
http://zwavepublic.com/sites/default/fi ... scales.pdf
