Multilevel Sensor: Channel #0 not updated to value of channel #1
DerLexus
Post by DerLexus » 13 Nov 2017 20:39
Hi there,
as stated here viewtopic.php?f=3427&t=23853&p=64223&hi ... vel#p64223 by PoltoS Z-Wave requires to have a channel #0 at the root device for a multilevel sensor. Z-Uno uses the value of Channel #1 for this. But since last sdk version the channel #0 stucks at the first value that was measured and does not change even if channel #1 has a different channel.
My sketch uses a temp sensor and the channel #0 shows 22.5 degrees even if the snow is falling (channel #1 shows something like 2.1 degrees).
Can anybody confirm this behaviour?
Thank you!
Bye
Re: Multilevel Sensor: Channel #0 not updated to value of channel #1
Post by PoltoS » 11 Dec 2017 19:41
Make sure to set up association in the life line group (#1). Better to place both association to controllerId and another multichannel association to controllerId:0
DerLexus
Post by DerLexus » 12 Dec 2017 17:56
Thanks for your reply! Do you mean i should use ZUNO_SETUP_ASSOCIATIONS macro?
Post by PoltoS » 17 Dec 2017 14:49
No, Life Line is here by default (group #1). Make sure to set it in your controller (good controllers should do that themselves)
