Making firmware file: C:\Users\knst\AppData\Local\Temp\arduino_build_371438/heating.ino-0211.hex ...packihx: read 974 lines, wrote 1881: OK.
Fixing ISR table in C:\Users\knst\AppData\Local\Temp\arduino_build_371438/heating.ino-0211.hex ...Making binary firmware file C:\Users\knst\AppData\Local\Temp\arduino_build_371438/heating.ino-0211.bin. Using in Z-Way for wireless update procedure.[Done]
Elapsed:14.6540000439 s
recipe.c.o.pattern pattern is missing
Error compiling for board Z-Wave>ME Z-Uno.
Arduino IDE: 1.8.5
Z-Uno core: 2.1.1
Manual compiler call works fine:
c:/Users/knst/AppData/Local/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.50/zuno_toolchain/compiler.exe build D:\mycode\Heating\code\src\heating\tmp\heating.ino -r c:/Users/knst/AppData/Local/Arduino15/packages/Z-Uno/hardware/zw8051/2.1.1 -p c:/Users/knst/AppData/Local/Arduino15/packages/Z-Uno/tools/zuno_toolchain/00.08.50/zuno_toolchain/sdcc/
Have a feeling that I need to completely remove IDE and z-uno from the system and reinstall to fix it but I've uninstalled IDE and deleted AppData/Local/Arduino15 then reinstalled IDE and it still gets z-uno somewhere - it just installs it, downloading step is skipped...
