Error in compilation with OneButton Library
Posted: 26 Dec 2017 16:29
I have a quick question, I'm trying to use the OneButton library.(https://github.com/mathertel/OneButton) I can get it to compile; but it runs into the following error.
This is my sketch code:
Am I doing something wrong? Or is this error related being incompatible with the Z-Uno? I use this library on my other Arduino's all the time. But I know that the Z-Uno has a more limited cpu package, so maybe that has something to do with it? Also I've commented out the attachClick function, but it gives me the same error on that function as well.
*** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: OneButton.cpp with SDCPP...
Compiling OneButton_sdcpp_.cpp ...
Preprocessing file: Switch.cpp with SDCPP...
Compiling Switch_sdcpp_.cpp ...['__cxx__Stream__method__findUntil_02p05p0d', '__cxx__OneButton__method__attachPress_0165', '__cxx__HardwareSerial__method__readBytes_02p0509', '__cxx__Stream__method__peekNextDigit_00', '__cxx__Print__method__print_010d', '__cxx__OneButton__method__attachDuringLongPress_0165', '__cxx__HardwareSerial__method__print_020905', '__cxx__Stream__method__getWriteError_00', '__cxx__Stream__method__read_00', '__cxx__Stream__method__findUntil_02p0dp0d', '__cxx__HardwareSerial__method__peekNextDigit_00', '__cxx__Stream__method__find_010d', '__cxx__Stream__method__println_021605', '__cxx__Stream__method__parseFloat_010d', '__cxx__Stream__method__write_02p0509', '__cxx__HardwareSerial__method__end_00', '__cxx__Stream__method__timedPeek_00', '__cxx__HardwareSerial__method__readBytes_02p0d09', '__cxx__HardwareSerial__method__getWriteError_00', '__cxx__HardwareSerial__method__setWriteError_0111', '__cxx__HardwareSerial__method__println_021105', '__cxx__Stream__method__dumpPrint_02p0505', '__cxx__Stream__method__setDumpLine_0105', '__cxx__Print__method__getWriteError_00', '__cxx__Stream__method__println_010d', '__cxx__OneButton__method__tick_00', '__cxx__Print__method__setWriteError_0111', '__cxx__Print__method__setDumpLine_0105', '__cxx__Stream__init00', '__cxx__HardwareSerial__init0105', '__cxx__Stream__method__print_020505', '__cxx__Print__method__fixPrint_021205', '__cxx__HardwareSerial__method__print_010d', '__cxx__HardwareSerial__method__print_020a05', '__cxx__Stream__method__timedRead_00', '__cxx__Stream__method__print_021505', '__cxx__Stream__method__println_021105', '__cxx__HardwareSerial__method__print_01p0d', '__cxx__Print__method__print_021205', '__cxx__HardwareSerial__method__find_02p0d09', '__cxx__HardwareSerial__method__timedPeek_00', '__cxx__Stream__method__print_021105', '__cxx__Stream__method__find_02p0d09', '__cxx__HardwareSerial__method__read_00', '__cxx__Print__method__print_020505', '__cxx__Print__method__print_020905', '__cxx__Print__method__dumpPrint_02p0505', '__cxx__Print__method__println_021205', '__cxx__Stream__method__print_021205', '__cxx__Print__method__print_021605', '__cxx__Stream__method__findUntil_04p0d09p0d09', '__cxx__Print__method__println_00', '__cxx__HardwareSerial__method__timedRead_00', '__cxx__HardwareSerial__method__fixPrint_021105', '__cxx__Stream__method__fixPrint_021205', '__cxx__Print__method__println_020905', '__cxx__HardwareSerial__method__println_021205', '__cxx__Stream__method__readBytes_02p0d09', '__cxx__OneButton__method__setDebounceTicks_0111', '__cxx__Stream__method__find_02p0509', '__cxx__HardwareSerial__method__setDumpLine_0105', '__cxx__Print__method__println_021605', '__cxx__Print__method__print_021505', '__cxx__HardwareSerial__method__parseFloat_010d', '__cxx__Stream__method__readBytes_02p0509', '__cxx__Stream__method__print_021605', '__cxx__Stream__method__parseInt_010d', '__cxx__HardwareSerial__method__available_00', '__cxx__Stream__method__readBytesUntil_030dp0509', '__cxx__Stream__method__println_021205', '__cxx__HardwareSerial__method__print_021105', '__cxx__OneButton__method__attachDoubleClick_0165', '__cxx__HardwareSerial__method__println_021605', '__cxx__HardwareSerial__method__readBytesUntil_030dp0d09', '__cxx__Print__init00', '__cxx__Stream__method__print_010d', '__cxx__HardwareSerial__method__find_02p0509', '__cxx__Print__method__print_021105', '__cxx__Stream__method__findMulti_02prMultiTarget11', '__cxx__Stream__method__peek_00', '__cxx__Stream__method__setWriteError_0111', '__cxx__HardwareSerial__method__fixPrint_021205', '__cxx__Stream__method__setTimeout_010a', '__cxx__OneButton__method__setPressTicks_0111', '__cxx__OneButton__method__isLongPressed_00', '__cxx__HardwareSerial__method__find_010d', '__cxx__Print__method__println_020505', '__cxx__HardwareSerial__method__findUntil_04p0d09p0d09', '__cxx__HardwareSerial__method__write_0112', '__cxx__HardwareSerial__method__write_0111', '__cxx__Stream__method__print_01p0d', '__cxx__HardwareSerial__method__write_010a', '__cxx__HardwareSerial__method__print_021505', '__cxx__HardwareSerial__method__parseFloat_00', '__cxx__HardwareSerial__method__find_01p05', '__cxx__Stream__method__println_020a05', '__cxx__OneButton__method__attachLongPressStop_0165', '__cxx__Stream__method__clearWriteError_00', '__cxx__Stream__method__fixPrint_021105', '__cxx__HardwareSerial__method__findUntil_02p05p0d', '__cxx__HardwareSerial__method__print_020505', '__cxx__HardwareSerial__method__println_00', '__cxx__HardwareSerial__method__write_02p0509', '__cxx__HardwareSerial__method__readBytesUntil_030dp0509', '__cxx__HardwareSerial__method__write_0105', '__cxx__Print__method__print_020a05', '__cxx__HardwareSerial__method__write_0109', '__cxx__Stream__method__println_00', '__cxx__HardwareSerial__method__parseInt_010d', '__cxx__Stream__method__flush_00', '__cxx__HardwareSerial__method__println_020905', '__cxx__Print__method__println_021505', '__cxx__OneButton__method__setClickTicks_0111', '__cxx__HardwareSerial__method__dumpPrint_02p0505', '__cxx__HardwareSerial__method__print_021605', '__cxx__HardwareSerial__method__println_020a05', '__cxx__Stream__method__readBytesUntil_030dp0d09', '__cxx__Stream__method__find_01p0d', '__cxx__HardwareSerial__method__begin_010a', '__cxx__Stream__method__parseInt_00', '__cxx__HardwareSerial__method__println_021505', '__cxx__HardwareSerial__method__findMulti_02prMultiTarget11', '__cxx__HardwareSerial__method__print_021205', '__cxx__Stream__method__available_00', '__cxx__Print__method__println_021105', '__cxx__Stream__method__print_020a05', '__cxx__HardwareSerial__method__setTimeout_010a', '__cxx__Print__method__clearWriteError_00', '__cxx__HardwareSerial__method__flush_00', '__cxx__HardwareSerial__method__clearWriteError_00', '__cxx__Stream__method__println_020905', '__cxx__Stream__method__println_021505', '__cxx__OneButton__init021111', '__cxx__OneButton__method__attachClick_0165', '__cxx__HardwareSerial__method__findUntil_02p0dp0d', '__cxx__HardwareSerial__method__begin__0109', '__cxx__Print__method__write_02p0509', '__cxx__Print__method__println_01p0d', '__cxx__Stream__method__write_0105', '__cxx__HardwareSerial__method__peek_00', '__cxx__Print__method__println_020a05', '__cxx__HardwareSerial__method__find_01p0d', '__cxx__Stream__method__find_01p05', '__cxx__HardwareSerial__method__begin_00', '__cxx__HardwareSerial__method__println_01p0d', '__cxx__Print__method__println_010d', '__cxx__Print__method__print_01p0d', '__cxx__HardwareSerial__method__parseInt_00', '__cxx__OneButton__method__attachLongPressStart_0165', '__cxx__Print__method__fixPrint_021105', '__cxx__HardwareSerial__method__println_020505', '__cxx__HardwareSerial__method__println_010d', '__cxx__Stream__method__println_020505', '__cxx__Stream__method__println_01p0d', '__cxx__Stream__method__parseFloat_00', '__cxx__Print__method__write_0105', '__cxx__Stream__method__print_020905']
Switch_sdcpp_.cpp:806:1:error: uCxx:Can't find method __cxx__OneButton__method__attachDoubleClick_01p6f for object btn1 of class OneButton
uCxx returned error code:-1This is my sketch code:
#include <OneButton.h>
// button pin number
#define BTN1_PIN 9
#define BTN2_PIN 10
#define BTN3_PIN 11
#define BTN4_PIN 12
#define BTN5_PIN 14
#define BTN6_PIN 15
// built in LED number
#define LED_PIN 13
// Button States
OneButton btn1(BTN1_PIN, true);
OneButton btn2(BTN2_PIN, true);
OneButton btn3(BTN3_PIN, true);
OneButton btn4(BTN4_PIN, true);
OneButton btn5(BTN5_PIN, true);
OneButton btn6(BTN6_PIN, true);
void setup() {
Serial.begin(9600);
pinMode(LED_PIN, OUTPUT);
pinMode(BTN1_PIN, INPUT_PULLUP);
pinMode(BTN2_PIN, INPUT_PULLUP);
pinMode(BTN3_PIN, INPUT_PULLUP);
pinMode(BTN4_PIN, INPUT_PULLUP);
pinMode(BTN5_PIN, INPUT_PULLUP);
pinMode(BTN6_PIN, INPUT_PULLUP);
Serial.println("Starting TwoButtons...");
// link button 1 functions
//btn1.attachClick(click1);
btn1.attachDoubleClick(doubleclick1);
btn1.attachLongPressStart(longPressStart1);
btn1.attachLongPressStop(longPressStop1);
btn1.attachDuringLongPress(longPress1);
// link button 2 functions
//btn2.attachClick(click2);
btn2.attachDoubleClick(doubleclick2);
btn2.attachLongPressStart(longPressStart2);
btn2.attachLongPressStop(longPressStop2);
btn2.attachDuringLongPress(longPress2);
void loop() {
// keep watching the push buttons:
btn1.tick();
btn2.tick();
// You can implement other code in here or just wait a while
delay(5);
// ----- button 1 callback functions
// This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
void click1() {
Serial.println("Button 1 click.");
} // click1
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclick1() {
Serial.println("Button 1 doubleclick.");
} // doubleclick1
// This function will be called once, when the button1 is pressed for a long time.
void longPressStart1() {
Serial.println("Button 1 longPress start");
} // longPressStart1
// This function will be called often, while the button1 is pressed for a long time.
void longPress1() {
Serial.println("Button 1 longPress...");
} // longPress1
// This function will be called once, when the button1 is released after beeing pressed for a long time.
void longPressStop1() {
Serial.println("Button 1 longPress stop");
} // longPressStop1
// ... and the same for button 2:
void click2() {
Serial.println("Button 2 click.");
} // click2
void doubleclick2() {
Serial.println("Button 2 doubleclick.");
} // doubleclick2
void longPressStart2() {
Serial.println("Button 2 longPress start");
} // longPressStart2
void longPress2() {
Serial.println("Button 2 longPress...");
} // longPress2
void longPressStop2() {
Serial.println("Button 2 longPress stop");
} // longPressStop2
