Light switch and Sensors
Vesuvious911
Post by Vesuvious911 »
Hello all,
I am trying to set up my z-uno to be a light switch and have different sensors like a door and temp sensor.
I am stuck however, I have the channels setup
ZUNO_SETUP_CHANNELS(
  ZUNO_SENSOR_MULTILEVEL_TEMPERATURE(getterTemperature),
  ZUNO_SENSOR_MULTILEVEL_HUMIDITY(getterHumidity),
  ZUNO_SENSOR_BINARY_DOOR_WINDOW(getterDoor),
  ZUNO_SWITCH_BINARY(getterLight, setterLight)
The binary switch channel isn't being transmitted to HomeAssistant. I can see my temperature, humidity, and the door sensor, it's just not creating the switch channel which is for a light. I'm not sure what I am missing. Because if I take out all the sensors and leave just the binary switch, it works and I can see it in HomeAssistant and toggle it. If anyone has any tips let me know. Thanks
Re: Light switch and Sensors
I suggest you to make Switch Binary the first in the list. Not sure how HomeAssistant is doing with Z-Wave spec, but looks it is sensetive to the type of first channel.
Vesuvious911
I did this, and I got it partially to work. The switch now shows up in HA but it seems like it isn't transmitting the data, and it also seems to kill the other channels. Z-Uno should be able to do both though correct? It should be able to be a switch and sensor all as one, do they have to be on specific pins or anything?
Tillsy
Post by Tillsy »
I've had similar issues for, as of tomorrow, three weeks now and getting nowhere...
When it comes to outputs Z-UNO is outstanding.
For inputs, crickets... you hear them... it's all I hear... :(
Here is a good description of how to do that in Vera
https://forum.z-wave.me/viewtopic.php?f ... =30#p73009
At least Tillsy is happy now ;))
But I assume HimeAssistant is not doing well with channels. Does it work for multichannel devices? Does it allow templates to be selected/edited?
